Changes between Version 10 and Version 11 of DevWikiGardenTest
10/08/09 04:53:11 (16 years ago)
robe
  • TabularUnified DevWikiGardenTest
    v10 v11
    4242This version skips the table creation battery of tests and allows you to specify a subset of functions to test.
    4343
    44 It will only test functions whose ids are contains in the fninclude flag.  NOTE this currently causes a bit of overtesting since ST_MakeLine and ST_M will match ST_MakeLine. Below is an example use.
     44This test is useful to test out new functions introduced or just test functions that have changed from prior
     45versions to make sure they are behaving as expected.  It makes the output file much shorter and easier to scan.
     46
     47It will only test functions whose ids are contained in the inputfninclude parameter.  NOTE this currently causes a bit of overtesting since ST_MakeLine and ST_M will match ST_MakeLine. Below is an example use.
    4548
    4649{{{
