Changes between Version 21 and Version 22 of DevWikiGardenTest
- 11/20/09 19:13:47 (15 years ago)
DevWikiGardenTest
v21 v22 3 3 The PostGIS Garden Test is a suite of SQL statements designed to stress test the PostGIS library within the PostgreSQL environment. It is a test generated from the reference.xml that tries to test every documented function against every kind of geometry supported by PostGIS. The main objective of the tests is to try to catch bugs that will crash the server. It is also useful for monitoring odd behavior as well as a regression test against prior versions of the software. To test against prior versions, build a test from the prior version reference.xml and test against both the old and the new version on the same server and then do a diff between the two. With postgis-1.4 and postgis-1.5 this is much easier to do as you can run both versions on the same server in different databases. 4 4 5 To build the garden test you need an xsltproc (the same that is used to build the docs or some other .xsl processor). On windows you can download precompiled binaries from [http://www.zlatkovic.com/pub/libxml/] and its part of the libxslt package. You may also need to download the iconv package and extract in same folder as your xsltproc.5 To build the garden test you need an xsltproc (the same that is used to build the docs or some other .xsl processor). On windows you can download precompiled binaries from [http://www.zlatkovic.com/pub/libxml/] and its part of the libxslt package. You may also need to download the iconv and zlib packages at same site and extract in same folder as your xsltproc.exe. 6 6 7 7 The reference.xml and postgis_gardentest.sql.xsl located in the doc and doc/xsl folders are both needed to build the tests.
