Changes between Version 35 and Version 36 of DevWikiGardenTest
12/03/10 05:25:51 (14 years ago)
robe
  • DevWikiGardenTest
    v35 v36
    77The (reference.xml or postgis.xml) and (postgis_gardentest.sql.xsl, raster_gardentest.sql.xsl (introduced in PostGIS 2.0) located in the doc and doc/xsl folders are both needed to build the tests.
    88
    9 NOTE: These tests are equivalent to a monkey testing the software so a lot of tests fail. It's good in a sense as a monkey will stuff a geometry, geography or raster in any function that takes that and as such will test the system as human monkeys are bound to do.
     9NOTE: These tests are equivalent to a monkey testing the software so a lot of tests fail. It's good in a sense as a monkey will stuff a geometry, geography or raster in any function that takes that and as such will test the system as human monkeys are bound to do.  As of PostGIS 2.0, there are currently about 70,000 some odd tests for the geometry/geography side and about 1600 tests for raster generated and run
    1010
    1111To Build the script
