Changes between Version 60 and Version 61 of DevWikiGardenTest
12/20/10 11:34:30 (14 years ago)
robe
  • TabularUnified DevWikiGardenTest
    v60 v61
    6666  * You can do a join between two log output tables by logid (as long as the logs were generated from the same test script) to compare results from different versions of postgis)
    6767
    68 Here is an example query I use to figure out which tests don't complete that used to complete in PostGIS 1.5.  Note for this -- I ran the PostGIS 1.5. batter of tests against a 1.5.2 install and a PostGIS 2.0 install and rename the log tables to be a bit more descriptive. The below will spit
    69 out all the tests that used to complete in postgis 1.5 install that now throw errors in postgis 2.0 install
     68Here is an example query I use to figure out which tests don't complete that used to complete in PostGIS 1.5.  Note for this -- I ran the PostGIS 1.5. battery of tests against a 1.5.2 install and a PostGIS 2.0 install and rename the log tables to be a bit more descriptive. The below will spit
     69out all the tests that used to complete in PostGIS 1.5 install that now throw errors in PostGIS 2.0 install
    7070
    7171{{{
