Changes between Version 7 and Version 8 of DevWikiMain/DevForDummy
- 02/24/16 03:11:24 (9 years ago)
v7 v8 32 32 * create a query with a distinct text_id as the first column 33 33 * add corresponding correct answer in dummy_expected file. Warning, line order matters 34 * if modifying regress_ogc 35 - be carefull, the function will be tested against sfcgal kernel and regular kernel 36 - a 2nd expecteed result file must be changed in sfcgal folder 34 37 - testing 35 38 * make
