Changes between Version 15 and Version 16 of DevWikiPostGISCoding
05/24/12 10:36:36 (13 years ago)
Bborie Park
added notes about allocating in ./raster/rt_core and ./raster/rt_pg
  • TabularUnified DevWikiPostGISCoding
    v15 v16
    55== PostgreSQL is the Man Behind the Curtain ==
    66
    7 All memory allocation in the ./liblwgeom directory should be done with lwalloc/lwfree/lwrealloc and in the ./postgis directory should be done with palloc/pfree/repalloc.   Why so?  At the core, memory management in PostGIS does not matter because PostgreSQL actually handles all memory in a "heirarchical memory manager" behind the scenes. That means PostgreSQL is the one calling the actual system malloc, and your palloc calls are managed by PostgreSQL inside larger pages ("contexts") that it mallocs. Each time a SQL function is called, PostgreSQL creates a new memory context and all your palloc/pfree calls happen in that context; when the SQL function call is complete, the whole context is discarded, which means any extra memory you failed to free (whoops!) is discarded too (phew!). Basically all your memory management is for naught, because PostgreSQL will clean up after the end of the function call.
     7All memory allocation in the ./liblwgeom directory should be done with lwalloc/lwfree/lwrealloc, in the ./postgis directory should be done with palloc/pfree/repalloc, in the ./raster/rt_core directory should be done with rtalloc/rtdealloc/rtrealloc and in the ./raster/rt_pg directory should be done with palloc/pfree/repalloc.   Why so?  At the core, memory management in PostGIS does not matter because PostgreSQL actually handles all memory in a "heirarchical memory manager" behind the scenes. That means PostgreSQL is the one calling the actual system malloc, and your palloc calls are managed by PostgreSQL inside larger pages ("contexts") that it mallocs. Each time a SQL function is called, PostgreSQL creates a new memory context and all your palloc/pfree calls happen in that context; when the SQL function call is complete, the whole context is discarded, which means any extra memory you failed to free (whoops!) is discarded too (phew!). Basically all your memory management is for naught, because PostgreSQL will clean up after the end of the function call.
    88
    99The lwalloc/lwfree calls in liblwgeom are themselves palloc/pfree calls when made within the context of the PostgreSQL engine. However, they can also be called outside of PostgreSQL, for example in the shp2pgsql and pgsql2shp utilities: in those cases they are direct calls to malloc/free. So memory management matters more in ./liblwgeom than in ./postgis. In ./liblwgeom there might not be someone cleaning up memory behind you.
