Changes between Version 118 and Version 119 of DevWikiWinMingW64
03/12/12 09:04:28 (13 years ago)
robe
  • DevWikiWinMingW64
    v118 v119
    1616'''mingw-w32-1.0-bin_i686-mingw_''' (for my purposes I used mingw-w32-1.0-bin_i686-mingw_20110408.zip) and for native 64-bit (currently using mingw-w64-1.0-bin_i686-mingw_20110516)
    1717
    18  * Extract your respective zip into a folder called C:\mingw_w64 or c:\mingw_w32
     18 * Extract your respective zip into a folder called C:\ming64\mingw64 or c:\ming32\mingw_w32
    1919
    2020
    3232}}}
    3333
    34 To your folder: C:\mingw\mingw64\x86_64-w64-mingw32\lib
     34To your folder: C:\ming64\x86_64-w64-mingw32\lib
    3535and then rename them adding a lib extensions so you have
    3636{{{
    5454
    5555When prompted type in
    56 {{{C:/mingw_w64/mingw}}} or {{{C:/mingw_w32/mingw}}}  depending on which tool chain you chose
     56{{{C:/ming64/mingw64}}} or {{{C:/ming32/mingw32}}}  depending on which tool chain you chose
    5757Once done, type logout and the console should exit.
    5858
    9393./configure --host=x86_64-w64-mingw32 --disable-shared --prefix=/mingw
    9494#if you are building on 32-bit then use --host=i686-w64-mingw32 for the host
     95#if you get a message that gcc is not usable, then you probably set your
     96# mingw setting wrong or did not install automake/autotools in /mingw
     97#try to fix by rerunning the sh /postinstall/pi.sh again
    9598make clean && make && make install
    9699libtool --version
