Changes between Version 150 and Version 151 of DevWikiWinMingW64
- 10/17/12 06:13:14 (12 years ago)
TabularUnified DevWikiWinMingW64
v150 v151 435 435 }}} 436 436 437 Before you'll be able to make check, you'll need your postgresql instance launched and the following files copied into the bin folder: 438 After you are done, make sure to copy the following files to your PostgreSQL bin folder: 439 440 {{{ 441 From your geos../bin *.dll 442 From your gdal../bin *.dll 443 FROM mingw64 (or mingw32) bin - libiconv-2.dll, libgcc_s_sjlj-1.dll, libstdc++-6.dll 444 From libxml/bin compile *.dll 445 From gdal/bin libgdal-1.dll (you'll also need zlib1.dll which you can copy from EDB install or download binary for) 446 From proj/bin -- libproj-0.dll 447 }}} 448 449 437 450 #this part is a hack, but again didn't work without it 438 451 #you can try without doing this, but if you get errors about … … 465 478 }}} 466 479 467 After you are done, make sure to copy the following files to your PostgreSQL bin folder:468 469 {{{470 From your geos/bin *.dll471 From your gdal/bin *.dll472 FROM ming/mingw64 (or mingw32) - libiconv-2.dll, libgcc_s_sjlj-1.dll, libstdc++-6.dll473 From libxml compile *.dll474 From gdal/bin libgdal-1.dll (you'll also need zlib1.dll which you can copy from EDB install or download binary for)475 From proj/bin -- libproj-0.dll476 }}}
