Changes between Version 151 and Version 152 of DevWikiWinMingW64
12/21/12 03:50:22 (12 years ago)
robe
  • DevWikiWinMingW64
    v151 v152
    22[wiki:UsersWikiWinCompile Back to Compiling in Windows]
    33If you want to get to the last step fast of just compiling PostGIS without having to compile the dependencies,
    4 you can download our prepared mingw64 bit chain which you can download from  [http://www.bostongis.com/postgisstuff/ming64.zip]
    5 , extract to C:\ming64, and launch the c:\ming64\msys\msys.bat and you should be on your way
     4you can download our prepared mingw64 bit chains which you can download from  [http://www.bostongis.com/postgisstuff/ming64.zip] and for 32-bit (for PostgreSQL 9.2+) [http://www.bostongis.com/postgisstuff/ming32.zip]
     5, extract to C:\ming64 and C:\ming32, and launch the corresponding c:\ming64\msys\msys.bat and you should be on your way
    66
    77and edit the file in C:\ming64\projects\postgis\builds\makepostgis20w64.sh
