Changes between Version 17 and Version 18 of DevWikiWinMingW64_21
- 05/02/13 22:14:48 (12 years ago)
TabularUnified DevWikiWinMingW64_21
v17 v18 5 5 you can download our prepared mingw64+msys build environment which you can download from [http://www.bostongis.com/postgisstuff/ming64.zip] and for 32-bit (for PostgreSQL 9.2+ (32-bit 9.1 and below have to use old msys chain) [http://www.bostongis.com/postgisstuff/ming32.zip] 6 6 7 If you want to start with your own mingw64 install and then add additional items refer to [ DevWikiMingW64_Setup]7 If you want to start with your own mingw64 install and then add additional items refer to [wiki:DevWikiMingW64_Setup] 8 8 == 3.b create project folders == 9 9
