Changes between Version 31 and Version 32 of DevWikiWinMingWSys_20
12/24/11 14:59:05 (13 years ago)
robe
  • DevWikiWinMingWSys_20
    v31 v32
    317317}}}
    318318
    319 == 16. Python GDAL bindings ==
    320 In order to compile raster these days, you now need Python with numpy and gdal bindings.
    321 So install your flavor of python if you don't have one from -- http://www.python.org/download/ (2.7 will work fine)
    322
    323 The most bullet proof and easiest install I have found for GDAL and numpy
    324 is the unofficial python libs from http://www.lfd.uci.edu/~gohlke/pythonlibs/
    325  * run Numpy:  numpy-1.5.1.win32-py2.6.exe,  numpy-1.5.1.win32-py2.7.exe
    326  * run GDAL-1.8.0.win32-py2.7.exe or GDAL-1.8.0.win32-py2.7.exe (listed in GDAL section)
     319== 16. GDAL ldconfig ==
     320In order for PostGIS to correctly use with GDALPolygonize
     321(Needed for floating point rasters) -- need something like
     322below set in your configure/compile script
     323
     324{{{
     325export LDFLAGS="-L/c/projects/GDAL/rel-trunk/lib"
     326}}}
     327
     328
    327329
    328330== 17. Compiling JSON-C ==
