Changes between Version 11 and Version 12 of GoogleSummerCode2019
03/28/19 08:40:45 (6 years ago)
robe
  • GoogleSummerCode2019
    v11 v12
    3636''Expected outcome'': Screen where users can browse for a zip file (or individuals files that make up an ESRI shape file set, and specify a table and load in.  This replaces the old shp2pgsql-gui that could be used as a plugin in pgAdmin3
    3737
     38[[Image(shp2pgsql-gui-import.png)]]
     39
    3840''Skills required'': Python, JavaScript and JavaScript APIs such as, require.js, bootstrap.  There is discussion of if you can use the shp2pgsql/pgsql2shp commandlines already packaged with most PostGIS distros, or if you should use the Python library shapely.
    3941
