Changes between Version 13 and Version 14 of GoogleSummerCode2019
03/28/19 08:44:25 (6 years ago)
robe
  • TabularUnified GoogleSummerCode2019
    v13 v14
    3838[[Image(shp2pgsql-gui-import.png)]] [[Image(shp2pgsql-gui-export.png)]]
    3939
    40 ''Skills required'': Python, JavaScript and JavaScript APIs such as, require.js, bootstrap.  There is discussion of if you can use the shp2pgsql/pgsql2shp commandlines already packaged with most PostGIS distros, or if you should use the Python library shapely.
     40''Skills required'': Python, JavaScript and JavaScript APIs such as, require.js, bootstrap.  There is discussion of if you can use the shp2pgsql/pgsql2shp commandlines already packaged with most PostGIS distros (similar to how pgAdmin4 uses pg_dump/pg_restore commandlines), or if you should use the Python library shapely.  [https://trac.osgeo.org/postgis/ticket/4358 Ticket #4358]
    4141
    4242''Mentors'': [https://www.osgeo.org/member/regina-obe/ Regina Obe], Frikan Erwee and [https://www.up.ac.za/geography-geoinformatics-and-meteorology/article/2735602/victoria-rautenbach Victoria Rautenbach]
