Changes between Version 21 and Version 22 of GoogleSummerCode2022
02/21/22 08:28:36 (3 years ago)
robe
  • TabularUnified GoogleSummerCode2022
    v21 v22
    7474
    75752) The tool would use the shp2pgsql and pgsql2shp commandlines that are part of the PostGIS source code in much the same way the backup and restore data browse menu options
    76 built into pgAdmin utilizes pg_dump / pg_restore. It will look for the executable files in default runtime folder or user specified binary path.
     76built into pgAdmin utilizes pg_dump / pg_restore.
     77It will look for the executable files in default runtime folder or user specified PostGIS binary path.
    7778
    78793)  If a particular table is selected, it will give option to export as a Dbase/Shapefile or import (append to) (no need to ask for table aside from export/import path) or append to
