Changes between Version 3 and Version 4 of InterWiki
02/01/17 00:39:16 (8 years ago)
  • TabularUnified InterWiki
    v3 v4
    55An InterWiki link can be used for referring to a Wiki page located in another Wiki system, and by extension, to any object located in any other Web application, provided a simple URL mapping can be done.
    66
    7 At the extreme, InterWiki prefixes can even be used to simply introduce links to new protocols, such as `tsvn:` used by [trac:TortoiseSvn TortoiseSvn].
     7InterWiki prefixes can even be used to simply introduce links to new protocols, such as `tsvn:` used by [trac:TortoiseSvn TortoiseSvn].
    88
    99== Link Syntax
    2727
    2828'''Example:'''
    29 {{{
     29{{{#!ini
    3030[interwiki]
    3131MeatBall = http://www.usemod.com/cgi-bin/mb.pl?
    6262
    6363Then,
    64  * `MoinMoin:InterWikiMap` should be rendered as MoinMoin:InterWikiMap and the ''title'' for that link would be "!InterWikiMap in !MoinMoin"
    65  * `Trac-ML:4346` should be rendered as Trac-ML:4346 and the ''title'' for that link would be "Message 4346 in Trac Mailing List"
     64 * `MoinMoin:InterWikiMap` should be rendered as MoinMoin:InterWikiMap and the ''title'' for that link would be "!InterWikiMap in !MoinMoin".
     65 * `Trac-ML:4346` should be rendered as Trac-ML:4346 and the ''title'' for that link would be "Message 4346 in Trac Mailing List".
    6666
    6767----
