Changes between Version 9 and Version 10 of SpatiaLite
01/15/12 07:16:08 (13 years ago)
aperi2007
  • SpatiaLite
    v9 v10
    2222  -dsco SPATIALITE=yes -lco SPATIAL_INDEX=yes -gt 65536 -gt
    2323}}}
    24 Some advertising: To avoid the lost of the third dimension exporting geometries you need use almost gdal 1.9.0 and spatialite lobrary 3.0.0.[[BR]]
     24Some advertising: To avoid the lost of the third dimension exporting geometries you need use almost gdal 1.9.0 and spatialite library 3.0.0.[[BR]]
    2525Also the exportation using the last sintax described don't export any field of type integer that is also a primary key. It don't lost the filed of type TEXT that are also primary keys. To avoid this lost you should use the "single table" call.
    2626
