Changes between Version 10 and Version 11 of SpatiaLite
01/15/12 07:17:27 (13 years ago)
aperi2007
  • SpatiaLite
    v10 v11
    2323}}}
    2424Some advertising: To avoid the lost of the third dimension exporting geometries you need use almost gdal 1.9.0 and spatialite library 3.0.0.[[BR]]
    25 Also the exportation using the last sintax described don't export any field of type integer that is also a primary key. It don't lost the filed of type TEXT that are also primary keys. To avoid this lost you should use the "single table" call.
     25Also the exportation using the last sintax described don't export any field of type integer that is also a primary key. Instead it don't lost the field
     26of type TEXT that are also primary keys. To avoid this lost you should use the "single table" call.
    2627
