Changes between Version 1 and Version 2 of TopologyTableRelation
04/09/12 08:02:46 (13 years ago)
martinl
  • TabularUnified TopologyTableRelation
    v1 v2
    1 Each postgis topology contains a "relation" table which defines the composition of every TopoGeometry bound to the topology. For each !TopoGeometry you have a set of element_type/element_id components. Interpretation of "element_type" depends on [wiki:TopologyTableLayer layer] definition: it is 1:Node, 2:Edge, 3:Face for non-hierarchical layers and a layer identifier for hierarchical layers.
     1== Topology Relation Table ==
     3Each PostGIS topology contains a "relation" table which defines the composition of every `TopoGeometry` bound to the topology. For each `TopoGeometry` you have a set of `element_type/element_id` components. Interpretation of "element_type" depends on [wiki:TopologyTableLayer layer] definition: it is 1:Node, 2:Edge, 3:Face for non-hierarchical layers and a layer identifier for hierarchical layers.
