Changes between Version 1 and Version 2 of TracCgi
06/10/10 13:36:30 (15 years ago)
  • TabularUnified TracCgi
    v1 v2
    11= Installing Trac as CGI =
    3 To install Trac as a CGI script, you need to make the `trac.cgi` executable as a CGI by your web server.
     3{{{
     4#!div class=important
     5  ''Please note that using Trac via CGI is the slowest deployment method available. It is slower than [TracModPython mod_python], [TracFastCgi FastCGI] and even [trac:TracOnWindowsIisAjp IIS/AJP] on Windows.''
     6}}}
    47
    5   ''Please note that using Trac via CGI is significantly slower than any other deployment method, such as [TracModPython mod_python] or [TracFastCgi FastCGI].''
     8CGI script is the entrypoint that web-server calls when a web-request to an application is made. To generate the `trac.cgi` script run:
     9{{{
     10trac-admin /path/to/env deploy /path/to/www/trac
     11}}}
     12`trac.cgi` will be in the `cgi-bin` folder inside the given path. Make sure it is executable by your web server. This command also copies `static resource` files to a `htdocs` directory of a given destination.
    613
    7 If you're using [http://httpd.apache.org/ Apache HTTPD], there are a couple ways to do that:
     14== Apache web-server configuration ==
    815
    9  1. Use a `ScriptAlias` to map a URL to the `trac.cgi` script
     16In [http://httpd.apache.org/ Apache] there are two ways to run Trac as CGI:
     17
     18 1. Use a `ScriptAlias` directive that maps an URL to the `trac.cgi` script (recommended)
    1019 2. Copy the `trac.cgi` file into the directory for CGI executables used by your web server (commonly named `cgi-bin`). You can also create a symbolic link, but in that case make sure that the `FollowSymLinks` option is enabled for the `cgi-bin` directory.
    1120
    12 The first option is recommended as it also allows you to map the CGI to a friendly URL.
    13
    14 Now, edit the Apache configuration file and add this snippet, file names and locations changed to match your installation:
     21To make Trac available at `http://yourhost.example.org/trac` add `ScriptAlias` directive to Apache configuration file, changing `trac.cgi` path to match your installation:
    1522{{{
    16 ScriptAlias /trac /usr/share/trac/cgi-bin/trac.cgi
     23ScriptAlias /trac /path/to/www/trac/cgi-bin/trac.cgi
    1724}}}
    1825
    19  ''Note that this directive requires the `mod_alias` module to be installed and enabled.''
     26 ''Note that this directive requires enabled `mod_alias` module.''
    2027
    2128If you're using Trac with a single project you need to set its location using the `TRAC_ENV` environment variable:
    3340}}}
    3441
    35  ''Note that the `SetEnv` directive requires the `mod_env` module to be installed and enable.''
     42 ''Note that the `SetEnv` directive requires enabled `mod_env` module. It is also possible to set TRAC_ENV in trac.cgi. Just add the following code between "try:" and "from trac.web ...":''
    3643
    37 This will make Trac available at `http://yourhost.example.org/trac`.
     44{{{
     45    import os
     46    os.environ['TRAC_ENV'] = "/path/to/projectenv"
     47}}}
     48
     49 '' Or for TRAC_ENV_PARENT_DIR: ''
     50
     51{{{
     52    import os
     53    os.environ['TRAC_ENV_PARENT_DIR'] = "/path/to/project/parent/dir"
     54}}}
    3855
    3956If you are using the [http://httpd.apache.org/docs/suexec.html Apache suEXEC] feature please see [http://trac.edgewall.org/wiki/ApacheSuexec].
    4360== Mapping Static Resources ==
    4461
    45 Out of the box, Trac will serve static resources such as style sheets or images itself. For a CGI setup, though, this is highly undesirable, because it results in the CGI script being invoked for documents that could be much more efficiently served by the web server directly.
     62Out of the box, Trac will pass static resources such as style sheets or images through itself. For a CGI setup this is '''highly undesirable''', because this way CGI script is invoked for documents that could be much more efficiently served directly by web server.
    4663
    47 Web servers such as [http://httpd.apache.org/ Apache HTTPD] allow you to create “Aliases” to resources, thereby giving them a virtual URL that doesn't necessarily bear any resemblance to the layout of the servers file system. We already used this capability above when defining a `ScriptAlias` for the CGI script, and we'll use it now to map requests to the static resources to the directory on the file system that contains them, thereby bypassing the processing of such requests by the CGI script.
     64Web servers such as [http://httpd.apache.org/ Apache] allow you to create “Aliases” to resources, giving them a virtual URL that doesn't necessarily reflect the layout of the servers file system. We already used this capability by defining a `ScriptAlias` for the CGI script. We also can map requests for static resources directly to the directory on the file system, avoiding processing these requests by CGI script.
    4865
    49 Edit the Apache configuration file again and add the following snippet '''before''' the `ScriptAlias` for the CGI script , file names and locations changed to match your installation:
     66Add the following snippet to Apache configuration '''before''' the `ScriptAlias` for the CGI script, changing paths to match your deployment:
    5067{{{
    51 Alias /trac/chrome/common /usr/share/trac/htdocs
    52 <Directory "/usr/share/trac/htdocs">
     68Alias /trac/chrome/common /path/to/www/trac/htdocs
     69<Directory "/path/to/www/trac/htdocs">
    5370  Order allow,deny
    5471  Allow from all
    5673}}}
    5774
    58 Note that whatever URL path you mapped the `trac.cgi` script to, the path `/chrome/common` is the path you have to append to that location to intercept requests to the static resources.
     75Note that we mapped `/trac` part of the URL to the `trac.cgi` script, and the path `/chrome/common` is the path you have to append to that location to intercept requests to the static resources.
    5976
    6077For example, if Trac is mapped to `/cgi-bin/trac.cgi` on your server, the URL of the Alias should be `/cgi-bin/trac.cgi/chrome/common`.
    6178
    62 Alternatively, you can set the `htdocs_location` configuration option in [wiki:TracIni trac.ini]:
     79Similarly, if you have static resources in a project's htdocs directory (which is referenced by /chrome/site URL in themes), you can configure Apache to serve those resources (again, put this '''before''' the `ScriptAlias` for the CGI script, and adjust names and locations to match your installation):
     80
     81{{{
     82Alias /trac/chrome/site /path/to/projectenv/htdocs
     83<Directory "/path/to/projectenv/htdocs">
     84  Order allow,deny
     85  Allow from all
     86</Directory>
     87}}}
     88
     89Alternatively to hacking `/trac/chrome/site`, you can directly specify path to static resources using `htdocs_location` configuration option in [wiki:TracIni trac.ini]:
    6390{{{
    6491[trac]
    65 htdocs_location = /trac-htdocs
     92htdocs_location = http://yourhost.example.org/trac-htdocs
    6693}}}
    6794
    6895Trac will then use this URL when embedding static resources into HTML pages. Of course, you still need to make the Trac `htdocs` directory available through the web server at the specified URL, for example by copying (or linking) the directory into the document root of the web server:
    6996{{{
    70 $ ln -s /usr/share/trac/htdocs /var/www/your_site.com/htdocs/trac-htdocs
     97$ ln -s /path/to/www/trac/htdocs /var/www/yourhost.example.org/trac-htdocs
    7198}}}
     100Note that in order to get this `htdocs` directory, you need first to extract the relevant Trac resources using the `deploy` command of TracAdmin:
     101[[TracAdminHelp(deploy)]]
     102
    72103
    73104== Adding Authentication ==
    113144}}}
    114145
    115 For better security, it is recommended that you either enable SSL or at least use the “Digest” authentication scheme instead of “Basic”. Please read the [http://httpd.apache.org/docs/2.0/ Apache HTTPD documentation] to find out more.
     146For better security, it is recommended that you either enable SSL or at least use the “digest” authentication scheme instead of “Basic”. Please read the [http://httpd.apache.org/docs/2.0/ Apache HTTPD documentation] to find out more. For example, on a Debian 4.0r1 (etch) system the relevant section  in apache configuration can look like this:
     147{{{
     148<Location "/trac/login">
     149    LoadModule auth_digest_module /usr/lib/apache2/modules/mod_auth_digest.so
     150    AuthType Digest
     151    AuthName "trac"
     152    AuthDigestDomain /trac
     153    AuthUserFile /somewhere/trac.htpasswd
     154    Require valid-user
     155</Location>
     156}}}
     157and you'll have to create your .htpasswd file with htdigest instead of htpasswd as follows:
     158{{{
     159# htdigest /somewhere/trac.htpasswd trac admin
     160}}}
     161where the "trac" parameter above is the same as !AuthName above  ("Realm" in apache-docs).
    116162
    117163----
    118 See also:  TracGuide, TracInstall, TracFastCgi, TracModPython
     164See also:  TracGuide, TracInstall, [wiki:TracModWSGI], TracFastCgi, TracModPython
