Changes between Version 1 and Version 2 of TracIni
06/10/10 13:36:30 (15 years ago)
  • TabularUnified TracIni
    v1 v2
    22[[TracGuideToc]]
    4 Trac configuration is done by editing the '''`trac.ini`''' config file, located in `<projectenv>/conf/trac.ini`.
     4Trac configuration is done by editing the '''`trac.ini`''' config file, located in `<projectenv>/conf/trac.ini`.  Changes to the configuration are usually reflected immediately, though changes to the `[components]` or `[logging]` sections will require restarting the web server. You may also need to restart the web server after creating a global configuration file when none was previously present.
     6The `trac.ini` configuration file should be writable by the web server, as Trac currently relies on the possibility to trigger a complete environment reload to flush its caches.
    57
    68== Global Configuration ==
    79
    8 Since version 0.9, Trac can also read the configuration from a global `trac.ini` file. These global options will then be merged with the environment-specific options, where local options override global options.
     10In versions prior to 0.11, the global configuration was by default located in `$prefix/share/trac/conf/trac.ini` or /etc/trac/trac.ini, depending on the distribution. If you're upgrading, you may want to specify that file to inherit from.  Literally, when you're upgrading to 0.11, you have to add an `[inherit]` section to your project's `trac.ini` file. Additionally, you have to move your customized templates and common images from `$prefix/share/trac/...` to the new location.
    911
    10 The global configuration is by default located in `$prefix/share/trac/conf/trac.ini`. It can be moved to a different location (for example, `/etc/trac.ini`), but that requires changing the file `trac/siteconfig.py` which gets created when Trac is installed.
     12Global options will be merged with the environment-specific options, where local options override global options. The options file is specified as follows:
     13{{{
     14[inherit]
     15file = /usr/share/trac/conf/trac.ini
     16}}}
     17
     18Note that you can also specify a global option file when creating a new project,  by adding the option `--inherit=/path/to/global/options` to [TracAdmin trac-admin]'s `initenv` command.  If do not do this but nevertheless intend to use a global option file with your new environment, you will have to go through the newly generated conf/trac.ini file and delete the entries that will otherwise override those set in the global file.
     19
    1120
    1221== Reference ==
    1423This is a brief reference of available configuration options.
    1524
    16 '''Note: since [milestone:0.10], the TracIni reference is auto-generated
    17 from the source code, using the TracIniMacro. But in this page, we will keep
    18 the old ''wiki'' content, so that documentation fixes could be easily
    19 contributed by the community, as before.'''
     25 ''Note that the [bitten], [spam-filter] and [vote] sections below are added by plugins enabled on this Trac, and therefore won't be part of a default installation.''
     27[[TracIni()]]
    2028
    2129
    22 == [trac] ==
    23 || `base_url` || Base URL of the Trac deployment.[[BR]]In most configurations, Trac will automatically reconstruct the URL that is used to access it automatically. However, in more complex setups, usually involving running Trac behind a HTTP proxy, you may need to use this option to force Trac to use the correct URL. ||
    24 || `database`        || [wiki:TracEnvironment#DatabaseConnectionStrings Database connection string] for this project ||
    25 || `default_charset` || Charset used in text files in the subversion repository (default is `iso-8859-15`) ||
    26 || `default_handler` || Name of the component that handles requests to the base URL (default is `WikiModule`. Some other options are `TimelineModule`, `RoadmapModule`, `BrowserModule`, `QueryModule`, ` ReportModule` and `NewticketModule`) (''since 0.9'') ||
    27 || `repository_dir`  || Path to local Subversion repository ||
    28 || `authz_file`      || Path to Subversion [http://svnbook.red-bean.com/en/1.1/ch06s04.html#svn-ch-6-sect-4.4.2 authorization (authz) file]. ||
    29 || `authz_module_name` || The module prefix used in the `authz_file` (See [http://projects.edgewall.com/trac/wiki/FineGrainedPermissions FineGrainedPermissions])||
    30 || `check_auth_ip` || Whether the IP address of the user should be checked for authentication (true, false) (''since 0.9'') ||
    31 || `ignore_auth_case` || Whether case should be ignored for login names (true, false) (''since 0.9'') ||
    32 || `templates_dir`   || Path to the !ClearSilver templates ||
    33 || `htdocs_location`   || Path to the static resources (default is `/trac`)||
    34 || `permissions_store` || ||
    35 || `metanav` || The order of the sections displayed in the meta nav bar, adding or removing section in this list is done with [wiki:TracPermissions trac's permission system] ||
    36 || `mainnav` || The order of the sections displayed in the main nav bar ||
    37
    38 == [diff] ==
    39 || `tab_width` || ''deprecated since 0.9 in favor of the `tab_width` option in the `[mimeviewer]` section'' ||
    40
    41 == [project] ==
    42 || `name`   || Project name ||
    43 || `descr`  || Short project description ||
    44 || `url`    || URL to the main project website ||
    45 || `icon`   || URL to icon file to use as shortcut icon (favicon) ||
    46 || `footer` || Page footer text (right-aligned) ||
    47
    48 == [header_logo] ==
    49 || `src`    || URL to image to use as header logo ||
    50 || `link`   || Destination URL to link to from header logo ||
    51 || `alt`    || ''alt'' text for header logo ||
    52 || `width`  || Header logo width in pixels ||
    53 || `height` || Header logo height in pixels ||
    54 See also: TracInterfaceCustomization.
    56 == [logging] ==
    57 || `log_type`  || Logging facility to use. (none, file, stderr, syslog, winlog) ||
    58 || `log_file`  || If ''log_type'' is ''file'', this should be a path to the log-file ||
    59 || `log_level` || Level of verbosity in log (CRITICAL, ERROR, WARN, INFO, DEBUG) ||
    60 See also: TracLogging
    61
    62 == [attachment] ==
    63 || `max_size` || Maximum allowed file size for ticket and wiki attachments ||
    64 || `render_unsafe_content` || Whether non-binary attachments should be rendered in the browser, or only made downloadable. Pretty much any text file may be interpreted as HTML by the browser, which allows a malicious user to attach a file containing cross-site scripting attacks. For public sites where anonymous users can create attachments, it is recommended to leave this option off (which is the default). ||
    65
    66 == [notification] ==
    67 || `smtp_enabled`   || Enable SMTP (email) notification (true, false) ||
    68 || `smtp_server`    || SMTP server hostname to use for email notifications (default: `localhost`) ||
    69 || `smtp_port`      || SMTP server port to use for email notifications (default: `25`)||
    70 || `smtp_user`      || Username for SMTP server (''since 0.9'') ||
    71 || `smtp_password`  || Password for SMTP server (''since 0.9'') ||
    72 || `smtp_from`      || Sender address to use in notification emails ||
    73 || `smtp_replyto`   || Reply-To address to use in notification emails ||
    74 || `smtp_default_domain` || Append the specified domain to addresses that do not contain one (''since 0.10'') ||
    75 || `smtp_always_cc` || Email address(es) to always send notifications to ||
    76 || `smtp_always_bcc` || Email address(es) to always send notifications to, but keep addresses not visible from other recipients (''since 0.10'') ||
    77 || `use_public_cc` || Recipients can see email addresses of other CC'ed recipients (''since 0.10'') ||
    78 || `use_short_addr` || Send username/login as is to the SMTP server (''since 0.10'') ||
    79 || `always_notify_reporter` || Always send notifications to any address in the ''reporter'' field ||
    80 || `always_notify_owner` || Always send notifications to the ticket owner (''since 0.9'') ||
    81 || `always_notify_updater` || The updater of a ticket receives a notification of his own changes (''since 0.10'') ||
    82 || `mime_encoding` || Specify the MIME encoding scheme for emails (''since 0.10'') ||
    83
    84 See also: TracNotification
    85
    86 == [mimeviewer] ==
    87 || `enscript_path` || Path to the Enscript program ||
    88 || `php_path` || Path to the PHP program ||
    89 || `max_preview_size` || Maximum file size for HTML preview (''since 0.9'') ||
    90 || `tab_width` || Displayed tab width in file preview (''since 0.9'') ||
    91
    92 == [ticket] ==
    93 || `default_version`   || Default version for newly created tickets ||
    94 || `default_severity`  || Default severity for newly created tickets ||
    95 || `default_priority`  || Default priority for newly created tickets ||
    96 || `default_milestone` || Default milestone for newly created tickets ||
    97 || `default_component` || Default component for newly created tickets ||
    98 || `default_type`      || Default type for newly created tickets ||
    99 || `restrict_owner`    || Make the owner field of tickets use a drop-down menu (''since 0.9''). See [wiki:TracTickets#Assign-toasDrop-DownList AssignToAsDropDownList] ||
    100
    101 == [ticket-custom] ==
    102 Creates [wiki:TracTicketsCustomFields user-defined ticket fields].
    103
    104 == [timeline] ==
    105 || `default_daysback` || Default "depth" of the Timeline, in days (''since 0.9'') ||
    106 || `changeset_show_files` || Number of files to show (-1 for unlimited, 0 to disable) ||
    107 || `ticket_show_details` || Enable the display of all ticket changes in the timeline (''since 0.9?'')||
    108
    109 == [browser] ==
    110 || `hide_properties` || List of subversion properties to hide from the repository browser (''since 0.9'') ||
    111
    112 == [wiki] ==
    113 || `ignore_missing_pages` || enable/disable highlighting CamelCase links to missing pages (''since 0.9'') ||
    114
    115 == [components] ==
    116 (''since 0.9'')
    117
     30== [components] == #components-section
    11831This section is used to enable or disable components provided by plugins, as well as by Trac itself. The component to enable/disable is specified via the name of the option. Whether its enabled is determined by the option value; setting the value to `enabled` or `on` will enable the component, any other value (typically `disabled` or `off`) will disable the component.
    11932
    12740}}}
    12841
    129 The first option tells Trac to disable the [wiki:TracReports report module]. The second option instructs Trac to enable all components in the `webadmin` package. Note that the trailing wildcard is required for module/package matching. To get a list of active components for your installation, see the ''Plugins'' page on ''About Trac'' (requires `CONFIG_VIEW` [wiki:TracPermissions permissions].)
     42The first option tells Trac to disable the [wiki:TracReports report module]. The second option instructs Trac to enable all components in the `webadmin` package. Note that the trailing wildcard is required for module/package matching.
     43
     44See the ''Plugins'' page on ''About Trac'' to get the list of active components (requires `CONFIG_VIEW` [wiki:TracPermissions permissions].)
    13045
    13146See also: TracPlugins
    13247
    133 == [changeset] ==
    134 (''since 0.10'')
     48== [ticket-custom] == #ticket-custom-section
    13549
    136 || `max_diff_bytes` || A limit for the sum of the size of all old ''and'' new files involved in a changeset. [[br]] Note that when requesting a diff precisely on a very big file (e.g. by the use of the ''Last Change'' link), the size limit will ''not'' be taken into account and the diffs will always be computed. ||
     50In this section, you can define additional fields for tickets. See TracTicketsCustomFields for more details.
     51
     52== [ticket-workflow] == #ticket-workflow-section
     53''(since 0.11)''
     54
     55The workflow for tickets is controlled by plugins.
     56By default, there's only a `ConfigurableTicketWorkflow` component in charge.
     57That component allows the workflow to be configured via this section in the trac.ini file.
     58See TracWorkflow for more details.
     59
     60== [milestone-groups] == #milestone-groups-section
     61''(since 0.11)''
     62
     63As the workflow for tickets is now configurable, there can be many ticket states,
     64and simply displaying closed tickets vs. all the others is maybe not appropriate
     65in all cases. This section enables one to easily create ''groups'' of states
     66that will be shown in different colors in the milestone progress bar.
     67
     68Example configuration (the default only has closed and active):
     69{{{
     70closed = closed
     71# sequence number in the progress bar
     72closed.order = 0
     73# optional extra param for the query (two additional columns: created and modified and sort on created)
     74group=resolution,order=time,col=id,col=summary,col=owner,col=type,col=priority,col=component,col=severity,col=time,col=changetime
     75# indicates groups that count for overall completion
     76closed.overall_completion = truepercentage
     78new = new
     79new.order = 1
     80new.css_class = new
     81new.label = new
     82
     83# one catch-all group is allowed
     84active = *
     85active.order = 2
     86# CSS class for this interval
     87active.css_class = open
     88# Displayed label for this group
     89active.label = in progress
     90}}}
     91
     92The definition consists in a comma-separated list of accepted status.
     93Also, '*' means any status and could be used to associate all remaining
     94states to one catch-all group.
     95
     96The CSS class can be one of: new (yellow), open (no color) or
     97closed (green). New styles can easily be added using the following
     98selector:  `table.progress td.<class>`
     100== [svn:externals] == #svn:externals-section
     101''(since 0.11)''
     102
     103The TracBrowser for Subversion can interpret the `svn:externals` property of folders out of the box.
     104However, if those externals are ''not'' using the `http:` or `https:` protocol, or if a link to a different repository browser such as another Trac or [http://www.viewvc.org/ ViewVC] is desired, then Trac needs to be able to map an external prefix to this other URL.
     105
     106This mapping is done in the `[svn:externals]` section of the TracIni
     107
     108Example:
     109{{{
     110[svn:externals]
     1111 = svn://server/repos1 http://trac/proj1/browser/$path?rev=$rev
     1122 = svn://server/repos2 http://trac/proj2/browser/$path?rev=$rev
     1133 = http://theirserver.org/svn/eng-soft       http://ourserver/viewvc/svn/$path/?pathrev=25914
     1144 = svn://anotherserver.com/tools_repository  http://ourserver/tracs/tools/browser/$path?rev=$rev
     115}}}
     116With the above, the `svn://anotherserver.com/tools_repository/tags/1.1/tools` external will be mapped to `http://ourserver/tracs/tools/browser/tags/1.1/tools?rev=` (and `rev` will be set to the appropriate revision number if the external additionally specifies a revision, see the [http://svnbook.red-bean.com/en/1.4/svn.advanced.externals.html SVN Book on externals] for more details).
     117
     118Note that the number used as a key in the above section is purely used as a place holder, as the URLs themselves can't be used as a key due to various limitations in the configuration file parser.
     119
     120Finally, the relative URLs introduced in [http://subversion.tigris.org/svn_1.5_releasenotes.html#externals Subversion 1.5] are not yet supported.
    137121
    138122----
