Changes between Version 4 and Version 5 of TracInstall
05/08/22 15:13:00 (3 years ago)
  • TabularUnified TracInstall
    v4 v5
    1 = Trac Installation Guide for 1.2
     1= Trac Installation Guide for 1.4
    22[[TracGuideToc]]
    4 Trac is written in the Python programming language and needs a database, [http://sqlite.org/ SQLite], [http://www.postgresql.org/ PostgreSQL], or [http://mysql.com/ MySQL]. For HTML rendering, Trac uses the [http://genshi.edgewall.org Genshi] templating system.
     4Trac is written in the Python programming language and needs a database, [https://sqlite.org/ SQLite], [https://www.postgresql.org/ PostgreSQL], or [https://mysql.com/ MySQL]. For HTML rendering, Trac uses the [http://jinja.pocoo.org Jinja2] templating system, though Genshi templates are supported until Trac 1.5.1.
    66Trac can also be localized, and there is probably a translation available in your language. If you want to use the Trac interface in other languages, then make sure you have installed the optional package [#OtherPythonPackages Babel]. Pay attention to the extra steps for localization support in the [#InstallingTrac Installing Trac] section below. Lacking Babel, you will only get the default English version.
    8 If you're interested in contributing new translations for other languages or enhancing the existing translations, then please have a look at [trac:wiki:TracL10N TracL10N].
     8If you're interested in contributing new translations for other languages or enhancing the existing translations, please have a look at [trac:wiki:TracL10N TracL10N].
    1010What follows are generic instructions for installing and setting up Trac. While you may find instructions for installing Trac on specific systems at [trac:TracInstallPlatforms TracInstallPlatforms], please '''first read through these general instructions''' to get a good understanding of the tasks involved.
    1616To install Trac, the following software packages must be installed:
    1717
    18  * [http://www.python.org/ Python], version >= 2.6 and < 3.0
    19    (note that we dropped the support for Python 2.5 in this release)
    20  * [http://pypi.python.org/pypi/setuptools setuptools], version >= 0.6
    21  * [http://genshi.edgewall.org/wiki/Download Genshi], version >= 0.6
     18 * [https://www.python.org/ Python], version >= 2.7 and < 3.0
     19   (note that we dropped the support for Python 2.6 in this release)
     20 * [https://pypi.org/project/setuptools setuptools], version >= 0.6
     21 * [https://pypi.org/project/Jinja2 Jinja2], version >= 2.9.3
     23{{{#!div style="border: 1pt dotted; margin: 1em"
     24**Setuptools Warning:** If the version of your setuptools is in the range 5.4 through 5.6, the environment variable `PKG_RESOURCES_CACHE_ZIP_MANIFESTS` must be set in order to avoid significant performance degradation. More information may be found in [#DeployingTrac Deploying Trac].
     25}}}
    2226
    2327You also need a database system and the corresponding python bindings. The database can be either SQLite, PostgreSQL or MySQL.
    2529==== For the SQLite database #ForSQLite
    2630
    27 As you must be using Python 2.6 or 2.7, you already have the SQLite database bindings bundled with the standard distribution of Python (the `sqlite3` module).
    28
    29 Optionally, you may install a newer version of [http://pypi.python.org/pypi/pysqlite pysqlite] than the one provided by the Python distribution. See [trac:PySqlite#ThePysqlite2bindings PySqlite] for details.
     31You already have the SQLite database bindings bundled with the standard distribution of Python (the `sqlite3` module).
     32
     33Optionally, you may install a newer version of [https://pypi.org/project/pysqlite pysqlite] than the one provided by the Python distribution. See [trac:PySqlite#ThePysqlite2bindings PySqlite] for details.
    3034
    3135==== For the PostgreSQL database #ForPostgreSQL
    3236
    3337You need to install the database and its Python bindings:
    34  * [http://www.postgresql.org/ PostgreSQL], version 8.0 or later
    35  * [http://pypi.python.org/pypi/psycopg2 psycopg2], version 2.0 or later
     38 * [https://www.postgresql.org/ PostgreSQL], version 9.1 or later
     39 * [https://pypi.org/project/psycopg2 psycopg2], version 2.0 or later
    3640
    3741See [trac:DatabaseBackend#Postgresql DatabaseBackend] for details.
    3943==== For the MySQL database #ForMySQL
    4044
    41 Trac works well with MySQL, provided you follow the guidelines:
    42
    43  * [http://mysql.com/ MySQL], version 5.0 or later
    44  * [http://sf.net/projects/mysql-python MySQLdb], version 1.2.2 or later
     45Trac works well with MySQL, provided you use the following:
     46
     47 * [https://mysql.com/ MySQL], version 5.0 or later
     48 * [https://pypi.org/project/PyMySQL PyMySQL]
    4549
    4650Given the caveats and known issues surrounding MySQL, read carefully the [trac:MySqlDb] page before creating the database.
    5054==== Subversion
    5155
    52 [http://subversion.apache.org/ Subversion], 1.6.x or later and the '''''corresponding''''' Python bindings.
    53
    54 There are [http://subversion.apache.org/packages.html pre-compiled SWIG bindings] available for various platforms. (Good luck finding precompiled SWIG bindings for any Windows package at that listing. [trac:TracSubversion] points you to [http://alagazam.net Alagazam], which works for me under Python 2.6.)
    56 For troubleshooting information, see the [trac:TracSubversion#Troubleshooting TracSubversion] page.
     56[https://subversion.apache.org/ Subversion], 1.6.x or later and the '''''corresponding''''' Python bindings.
     57
     58There are [https://subversion.apache.org/packages.html pre-compiled SWIG bindings] available for various platforms. See [trac:TracSubversion#GettingSubversion getting Subversion] for more information.
    5759
    5860{{{#!div style="border: 1pt dotted; margin: 1em"
    5961**Note:**
    6062* Trac '''doesn't''' use [http://pysvn.tigris.org/ PySVN], nor does it work yet with the newer `ctype`-style bindings.
    61 * If using Subversion, Trac must be installed on the '''same machine'''. Remote repositories are currently [trac:ticket:493 not supported].
    62 }}}
     63* If using Subversion, Trac must be installed on the '''same machine'''. Remote repositories are [trac:ticket:493 not supported].
     64}}}
     65
     66For troubleshooting information, see the [trac:TracSubversion#Troubleshooting TracSubversion] page.
    6367
    6468==== Git
    6569
    66 [http://git-scm.com/ Git] 1.5.6 or later is supported. More information is available on the [trac:TracGit] page.
     70[https://git-scm.com/ Git] 1.5.6 or later is supported. More information is available on the [trac:TracGit] page.
    6771
    6872==== Other Version Control Systems
    7478
    7579Alternatively you can configure Trac to run in any of the following environments:
    76  * [http://httpd.apache.org/ Apache] with
    77    - [https://github.com/GrahamDumpleton/mod_wsgi mod_wsgi], see [wiki:TracModWSGI] and
    78      [http://code.google.com/p/modwsgi/wiki/IntegrationWithTrac ModWSGI IntegrationWithTrac].
     80 * [https://httpd.apache.org/ Apache] with
     81   - [https://github.com/GrahamDumpleton/mod_wsgi mod_wsgi], see [wiki:TracModWSGI] and
     82     [https://code.google.com/p/modwsgi/wiki/IntegrationWithTrac ModWSGI IntegrationWithTrac].
    7983   - [http://modpython.org/ mod_python 3.5.0], see TracModPython
    80  * a [http://www.fastcgi.com/ FastCGI]-capable web server (see TracFastCgi)
    81  * an [http://tomcat.apache.org/connectors-doc/ajp/ajpv13a.html AJP]-capable web
     84 * a [https://fastcgi-archives.github.io FastCGI]-capable web server (see TracFastCgi)
     85 * an [https://tomcat.apache.org/connectors-doc/ajp/ajpv13a.html AJP]-capable web
    8286   server (see [trac:TracOnWindowsIisAjp TracOnWindowsIisAjp])
    8387 * Microsoft IIS with FastCGI and a FastCGI-to-WSGI gateway (see [trac:CookBook/Installation/TracOnWindowsIisWfastcgi IIS with FastCGI])
    84  * a CGI-capable web server (see TracCgi), '''but usage of Trac as a cgi script
    85    is highly discouraged''', better use one of the previous options.
    86
     88 * a CGI-capable web server (see TracCgi), '''but usage of Trac as a cgi script
     89   is highly discouraged''', better use one of the previous options.
     90
    8791
    8892==== Other Python Packages
    8993
    90  * [http://babel.edgewall.org Babel], version 0.9.6 or >= 1.3,
     94 * [http://babel.pocoo.org Babel], version 0.9.6 or >= 1.3,
    9195   needed for localization support
    92  * [http://docutils.sourceforge.net/ docutils], version >= 0.3.9
     96 * [http://pytz.sourceforge.net pytz] to get a complete list of time zones,
     97   otherwise Trac will fall back on a shorter list from
     98   an internal time zone implementation. Installing Babel
     99   will install pytz.
     100 * [http://docutils.sourceforge.net docutils], version >= 0.3.9
    93101   for WikiRestructuredText.
    94  * [http://pygments.org Pygments] for
     102 * [http://pygments.org Pygments] for
    95103   [TracSyntaxColoring syntax highlighting].
    96  * [http://pytz.sf.net pytz] to get a complete list of time zones,
     104 * [https://pypi.org/project/textile Textile] for rendering the [https://github.com/textile/python-textile Textile markup language].
     105 * [https://pypi.org/project/passlib passlib] on Windows to decode [TracStandalone#BasicAuthorization:Usingahtpasswdpasswordfile htpasswd formats] other than `SHA-1`.
     106 * [https://pypi.org/project/pyreadline pyreadline] on Windows for trac-admin [TracAdmin#InteractiveMode command completion].
    99107
    100108{{{#!div style="border: 1pt dotted; margin: 1em"
    110118It is assumed throughout this guide that you have elevated permissions as the `root` user or by prefixing commands with `sudo`. The umask `0002` should be used for a typical installation on a Unix-based platform.
    111119
    112 === Using `easy_install`
    113 Trac can be installed from PyPI or the Subversion repository using [http://pypi.python.org/pypi/setuptools setuptools].
    114
    115 A few examples:
    116
    117  - Install the latest stable version of Trac:
    118  {{{#!sh
    119 $ easy_install Trac
    120 }}}
    121  - Install latest development version:
    122  {{{#!sh
    123 $ easy_install http://download.edgewall.org/trac/Trac-latest-dev.tar.gz
    124 }}}
    125    Note that in this case you won't have the possibility to run a localized version of Trac;
    126    either use a released version or install from source
    127
    128 More information can be found on the [trac:wiki:setuptools setuptools] page.
    129
    130 {{{#!div style="border: 1pt dotted; margin: 1em"
    131 **Setuptools Warning:** If the version of your setuptools is in the range 5.4 through 5.6, the environment variable `PKG_RESOURCES_CACHE_ZIP_MANIFESTS` must be set in order to avoid significant performance degradation. More information may be found in [#DeployingTrac Deploying Trac].
    132 }}}
    133
    134120=== Using `pip`
    135 'pip' is an easy_install replacement that is very useful to quickly install python packages.
    136 To get a Trac installation up and running in less than 5 minutes:
    137
    138 Assuming you want to have your entire pip installation in `/opt/user/trac`
    139
    140  -
    141  {{{#!sh
    142 $ pip install trac psycopg2
    143 }}}
    144 or
    145  -
    146  {{{#!sh
    147 $ pip install trac mysql-python
    148 }}}
    149
    150 Make sure your OS specific headers are available for pip to automatically build PostgreSQL (`libpq-dev`) or MySQL (`libmysqlclient-dev`) bindings.
    151
    152 pip will automatically resolve all dependencies (like Genshi, pygments, etc.), download the latest packages from pypi.python.org and create a self contained installation in `/opt/user/trac`.
    153
    154 All commands (`tracd`, `trac-admin`) are available in `/opt/user/trac/bin`. This can also be leveraged for `mod_python` (using `PythonHandler` directive) and `mod_wsgi` (using `WSGIDaemonProcess` directive)
    155
    156 Additionally, you can install several Trac plugins (listed [https://pypi.python.org/pypi?:action=browse&show=all&c=516 here]) through pip.
    157
    158 === From source
    159 Using the python-typical setup at the top of the source directory also works. You can obtain the source for a .tar.gz or .zip file corresponding to a release (e.g. `Trac-1.0.tar.gz`) from the [trac:TracDownload] page, or you can get the source directly from the repository. See [trac:TracRepositories#OfficialSubversionrepository TracRepositories] for details.
    160
    161 {{{#!sh
    162 $ python ./setup.py install
    163 }}}
    164
    165 ''You will need root permissions or equivalent for this step.''
    166
    167 This will byte-compile the Python source code and install it as an .egg file or folder in the `site-packages` directory
    168 of your Python installation. The .egg will also contain all other resources needed by standard Trac, such as `htdocs` and `templates`.
    169
    170 If you install from source and want to make Trac available in other languages, make sure Babel is installed. Only then, perform the `install` (or simply redo the `install` once again afterwards if you realize Babel was not yet installed):
    171 {{{#!sh
    172 $ python ./setup.py install
    173 }}}
    174 Alternatively, you can run `bdist_egg` and copy the .egg from `dist/` to the place of your choice, or you can create a Windows installer (`bdist_wininst`).
     121`pip` is the modern Python package manager and is included in Python 2.7.9 and later. Use [https://bootstrap.pypa.io/get-pip.py get-pip.py] to install `pip` for an earlier version of Python.
     122
     123{{{#!sh
     124$ pip install Trac
     125}}}
     126
     127`pip` will automatically resolve the //required// dependencies (Jinja2 and setuptools) and download the latest packages from pypi.org.
     128
     129You can also install directly from a source package. You can obtain the source in a tar or zip from the [trac:TracDownload] page. After extracting the archive, change to the directory containing `setup.py` and run:
     130
     131{{{#!sh
     132$ pip install .
     133}}}
     134
     135`pip` supports numerous other install mechanisms. It can be passed the URL of an archive or other download location. Here are some examples:
     136
     137* Install the latest stable version from a zip archive:
     138{{{#!sh
     139$ pip install https://download.edgewall.org/trac/Trac-latest.zip
     140}}}
     141* Install the latest development version from a tar archive:
     142{{{#!sh
     143$ pip install https://download.edgewall.org/trac/Trac-latest-dev.tar.gz
     144}}}
     145* Install the unreleased 1.2-stable from subversion:
     146{{{#!sh
     147$ pip install svn+https://svn.edgewall.org/repos/trac/branches/1.2-stable
     148}}}
     149* Install the latest development preview (//not recommended for production installs//):
     150{{{#!sh
     151$ pip install --find-links=https://trac.edgewall.org/wiki/TracDownload Trac
     152}}}
     153
     154The optional dependencies can be installed from PyPI using `pip`:
     155{{{#!sh
     156$ pip install babel docutils pygments textile
     157}}}
     158
     159The optional dependencies can alternatively be
     160specified using the `extras` keys in the setup file:
     161{{{#!sh
     162$ pip install Trac[babel,rest,pygments,textile]
     163}}}
     164
     165`rest` is the extra that installs the `docutils`
     166dependency.
     167
     168Include `mysql` or `psycopg2-binary` in the
     169list if using the MySQL or PostgreSQL database.
     170
     171Additionally, you can install several Trac plugins from PyPI (listed [https://pypi.org/search/?c=Framework+%3A%3A+Trac here]) using pip. See TracPlugins for more information.
    175172
    176173=== Using installer
    180177=== Using package manager
    181178
    182 Trac may be available in your platform's package repository. Note however, that the version provided by your package manager may not be the latest release.
    183
    184 === Advanced `easy_install` Options
    185
    186 To install Trac to a custom location, or find out about other advanced installation options, run:
    187 {{{#!sh
    188 $ easy_install --help
    189 }}}
    190
    191 Also see [http://docs.python.org/2/install/index.html Installing Python Modules] for detailed information.
    192
    193 Specifically, you might be interested in:
    194 {{{#!sh
    195 $ easy_install --prefix=/path/to/installdir
    196 }}}
    197 or, if installing Trac on a Mac OS X system:
    198 {{{#!sh
    199 $ easy_install --prefix=/usr/local --install-dir=/Library/Python/2.6/site-packages
    200 }}}
    201
    202 {{{#!div style="border: 1pt dotted; margin: 1em"
    203 **Mac OS X Note:** On Mac OS X 10.6,  running `easy_install trac` will install into `/usr/local` and `/Library/Python/2.6/site-packages` by default.
    204
    205 The `tracd` and `trac-admin` commands will be placed in `/usr/local/bin` and will install the Trac libraries and dependencies into `/Library/Python/2.6/site-packages`, which is Apple's preferred location for third-party Python application installations.
    206 }}}
     179Trac may be available in your platform's package repository. However, your package manager may not provide the latest release of Trac.
    207180
    208181== Creating a Project Environment
    215188}}}
    216189
    217 [TracAdmin trac-admin] will prompt you for the information it needs to create the environment: the name of the project and the [TracEnvironment#DatabaseConnectionStrings database connection string]. If you're not sure what to specify for any of these options, just press `<Enter>` to use the default value.
     190[TracAdmin trac-admin] will prompt you for the information it needs to create the environment: the name of the project and the [TracEnvironment#DatabaseConnectionStrings database connection string]. If you're not sure what to specify for any of these options, just press `<Enter>` to use the default value.
    218191
    219192Using the default database connection string will always work as long as you have SQLite installed. For the other [trac:DatabaseBackend database backends] you should plan ahead and already have a database ready to use at this point.
    220193
    221194Also note that the values you specify here can be changed later using TracAdmin or directly editing the [TracIni conf/trac.ini] configuration file.
    222
    223 {{{#!div style="border: 1pt dotted; margin: 1em"
    224 **Filesystem Warning:** When selecting the location of your environment, make sure that the filesystem on which the environment directory resides supports sub-second timestamps (i.e. **not** `ext2` or `ext3` on Linux, or HFS+ on OSX), as the modification time of the `conf/trac.ini` file will be monitored to decide whether an environment restart is needed or not. A too coarse-grained timestamp resolution may result in inconsistencies in Trac < 1.0.2. The best advice is to opt for a platform with sub-second timestamp resolution, regardless of the Trac version.
    225 }}}
    226195
    227196Finally, make sure the user account under which the web front-end runs will have '''write permissions''' to the environment directory and all the files inside. This will be the case if you run `trac-admin ... initenv` as this user. If not, you should set the correct user afterwards. For example on Linux, with the web server running as user `apache` and group `apache`, enter:
    263232}}}
    264233
    265 Then, fire up a browser and visit `http://localhost:8000/`. You should get a simple listing of all environments that `tracd` knows about. Follow the link to the environment you just created, and you should see Trac in action. If you only plan on managing a single project with Trac you can have the standalone server skip the environment list by starting it like this:
     234Then, open a browser and visit `http://localhost:8000/`. You should get a simple listing of all environments that `tracd` knows about. Follow the link to the environment you just created, and you should see Trac in action. If you only plan on managing a single project with Trac you can have the standalone server skip the environment list by starting it like this:
    266235{{{#!sh
    267236$ tracd -s --port 8000 /path/to/myproject
    270239=== Running Trac on a Web Server
    271240
    272 Trac provides various options for connecting to a "real" web server:
     241Trac provides various options for connecting to a "real" web server:
    273242 - [TracFastCgi FastCGI]
    274  - [wiki:TracModWSGI Apache with mod_wsgi]
     243 - [wiki:TracModWSGI Apache with mod_wsgi]
    275244 - [TracModPython Apache with mod_python]
    276  - //[TracCgi CGI] (should not be used, as the performance is far from optimal)//
    277
    278 Trac also supports [trac:TracOnWindowsIisAjp AJP] which may be your choice if you want to connect to IIS. Other deployment scenarios are possible: [trac:TracNginxRecipe nginx], [http://projects.unbit.it/uwsgi/wiki/Example#Traconapacheinasub-uri uwsgi], [trac:TracOnWindowsIisIsapi Isapi-wsgi] etc.
     245 - [TracCgi CGI] //(should not be used, as the performance is far from optimal)//
     246
     247Trac also supports [trac:TracOnWindowsIisAjp AJP] which may be your choice if you want to connect to IIS. Other deployment scenarios are possible: [trac:TracNginxRecipe nginx], [https://uwsgi-docs.readthedocs.io/en/latest/#Traconapacheinasub-uri uwsgi], [trac:TracOnWindowsIisIsapi Isapi-wsgi] etc.
    279248
    280249==== Generating the Trac cgi-bin directory #cgi-bin
    281250
    282 In order for Trac to function properly with FastCGI you need to have a `trac.fcgi` file and for mod_wsgi a `trac.wsgi` file. These are Python scripts which load the appropriate Python code. They can be generated using the `deploy` option of [TracAdmin trac-admin].
    283
    284 There is, however, a bit of a chicken-and-egg problem. The [TracAdmin trac-admin] command requires an existing environment to function, but complains if the deploy directory already exists. This is a problem, because environments are often stored in a subdirectory of the deploy. The solution is to do something like this:
    285 {{{#!sh
    286 $ mkdir -p /usr/share/trac/projects/my-project
    287 $ trac-admin /usr/share/trac/projects/my-project initenv
    288 $ trac-admin /usr/share/trac/projects/my-project deploy /tmp/deploy
    289 $ mv /tmp/deploy/* /usr/share/trac
    290 }}}
    291 Don't forget to check that the web server has the execution right on scripts in the `/usr/share/trac/cgi-bin` directory.
     251Application scripts for CGI, FastCGI and mod-wsgi can be generated using the [TracAdmin trac-admin] `deploy` command:
     252[[TracAdminHelp(deploy)]]
     253
     254Grant the web server execution right on scripts in the `cgi-bin` directory.
     255
     256For example, the following yields a typical directory structure:
     257{{{#!sh
     258$ mkdir -p /var/trac
     259$ trac-admin /var/trac/<project> initenv
     260$ trac-admin /var/trac/<project> deploy /var/www
     261$ ls /var/www
     262cgi-bin htdocs
     263$ chmod ugo+x /var/www/cgi-bin/*
     264}}}
    292265
    293266==== Mapping Static Resources
    295268Without additional configuration, Trac will handle requests for static resources such as stylesheets and images. For anything other than a TracStandalone deployment, this is not optimal as the web server can be set up to directly serve the static resources. For CGI setup, this is '''highly undesirable''' as it causes abysmal performance.
    296269
    297 Web servers such as [http://httpd.apache.org/ Apache] allow you to create //Aliases// to resources, giving them a virtual URL that doesn't necessarily reflect their location on the file system. We can map requests for static resources directly to directories on the file system, to avoid Trac processing the requests.
     270Web servers such as [https://httpd.apache.org/ Apache] allow you to create //Aliases// to resources, giving them a virtual URL that doesn't necessarily reflect their location on the file system. We can map requests for static resources directly to directories on the file system, to avoid Trac processing the requests.
    298271
    299272There are two primary URL paths for static resources: `/chrome/common` and `/chrome/site`. Plugins can add their own resources, usually accessible at the `/chrome/<plugin>` path.
    300273
    301 A single `/chrome` alias can used if the static resources are extracted for all plugins. This means that the `deploy` command must be executed after installing or updating a plugin that provides static resources, or after modifying resources in the `$env/htdocs` directory. This is probably appropriate for most installations but may not be what you want if, for example, you wish to upload plugins through the //Plugins// administration page.
    302
    303 The resources are extracted using the [TracAdmin trac-admin]` <environment> deploy` command:
    304 [[TracAdminHelp(deploy)]]
    305
    306 The target `<directory>` will contain an `htdocs` directory with:
     274A single `/chrome` alias can used if the static resources are extracted for all plugins. This means that the `deploy` command (discussed in the previous section) must be executed after installing or updating a plugin that provides static resources, or after modifying resources in the `$env/htdocs` directory. This is probably appropriate for most installations but may not be what you want if, for example, you wish to upload plugins through the //Plugins// administration page.
     275
     276The `deploy` command creates an `htdocs` directory with:
    307277 - `common/` - the static resources of Trac
    308278 - `site/` - a copy of the environment's `htdocs/` directory
    322292Assuming the deployment has been done this way:
    323293{{{#!sh
    324 $ trac-admin /var/trac/env deploy /path/to/shared/trac
     294$ trac-admin /var/trac/<project> deploy /var/www
    325295}}}
    326296
    366336}}}
    367337
    368 Another alternative to aliasing `/trac/chrome/common` is having Trac generate direct links for those static resources (and only those), using the [[TracIni#trac-section| [trac] htdocs_location]] configuration setting:
     338Another alternative to aliasing `/trac/chrome/common` is having Trac generate direct links for those static resources (and only those), using the [TracIni#trac-htdocs_location-option trac.htdocs_location] configuration setting:
    369339{{{#!ini
    370340[trac]
    387357Trac uses HTTP authentication. You'll need to configure your webserver to request authentication when the `.../login` URL is hit (the virtual path of the "login" button). Trac will automatically pick the `REMOTE_USER` variable up after you provide your credentials. Therefore, all user management goes through your web server configuration. Please consult the documentation of your web server for more info.
    388358
    389 The process of adding, removing, and configuring user accounts for authentication depends on the specific way you run Trac.
     359The process of adding, removing, and configuring user accounts for authentication depends on the specific way you run Trac.
    390360
    391361Please refer to one of the following sections:
    406376== Configuring Trac
    407377
     378Configuration options are documented on the TracIni page.
     379
    408380TracRepositoryAdmin provides information on configuring version control repositories for your project.
    409381
     382In addition to the optional version control backends, Trac provides several optional features that are disabled by default:
     383* [TracFineGrainedPermissions#AuthzPolicy Fine-grained permission policy]
     384* [TracPermissions#CreatingNewPrivileges Custom permissions]
     385* [TracTickets#deleter Ticket deletion]
     386* [TracTickets#cloner Ticket cloning]
     387* [TracRepositoryAdmin#CommitTicketUpdater Ticket changeset references]
     388
    410389== Using Trac
    411390
    419398
    420399----
    421 See also: [trac:TracInstallPlatforms TracInstallPlatforms], TracGuide, TracUpgrade, TracPermissions
     400See also: [trac:TracInstallPlatforms TracInstallPlatforms], TracGuide, TracUpgrade
