Changes between Version 3 and Version 4 of TracTimeline
05/08/22 15:13:00 (3 years ago)
  • TabularUnified TracTimeline
    v3 v4
    22[[TracGuideToc]]
    4 Trac's timeline feature provides a historic view of the project in a single report.
     4Trac's timeline feature provides a historic view of the project.
    6 It lists all Trac events that have occurred in chronological order, a brief description of each event and if applicable, the person responsible for the change.
     6Trac events are listed in chronological order, comprised of a brief description of each event and, if applicable, the person responsible for the change.
    88The timeline lists these kinds of events:
    9  * '''Wiki page events''' — Creation and changes
    10  * '''Ticket events''' — Creation and resolution/closing and optionally other changes
     9 * '''Wiki page events''' — Pages created and edited
     10 * '''Ticket events''' — Tickets open/closed and updated
    1111 * '''Source code changes ''' — Repository check-ins
    12  * '''Milestone ''' — Milestone completed
     12 * '''Milestone events''' — Milestones completed
    1313
    14 Each event entry provides a hyperlink to the specific event in question, who authored the change as well as a brief excerpt of the actual comment or text, if available.
     14Each event entry provides a hyperlink to the event, the author of the change, as well as a brief excerpt of the actual comment or text, if available. Plugins may provide additional events for the timeline.
    1515
    16 It is possible to filter the displayed events with the various filters in the option panel:
    17  * ''View changes from'' — the date from which to start displaying events (current date if empty). Events that occurred after this date will not be shown, only those that occurred before that date.
     16The displayed events can be filtered using the filters in the preferences panel:
     17 * ''View changes from'' — the date from which to start displaying events (current date if empty). Events that occurred after this date will not be shown, only those that occurred before the date.
    1818 * ''and X days back'' — how many days backwards in time to get events.
    19  * ''done by'' — the author of an event. It accepts a space-separated list of authors for which events should be included. Alternatively, if the author names are prefixed by a "-" character, then the events having those authors will be excluded, and all the others included. Single or double quotes can be used for specifying author names containing space characters. ''(since 0.12)''
    20  * ''Changesets in all repositories'' — if you have more than one repository connected to your Trac project, then you can filter the output so events from specific repositories are not shown. ''(since 0.12)''
    21  * ''Milestones reached'' — display or hide milestones reached.
    22  * ''Opened and closed tickets'' — display or hide ticket open or close events.
     19 * ''done by'' — the author of an event. It accepts a space-separated list of authors for which events should be included. Alternatively, if the author names are prefixed by a `-` character, then the events having those authors will be excluded, and all the others included. Single or double quotes can be used for specifying author names containing space characters.
     20 * ''Changesets in all repositories'' — if you have more than one repository connected to your Trac project, you can also filter events from specific repositories.
     21 * ''Milestones completed'' — display or hide milestones reached.
     22 * ''Tickets opened and closed'' — display or hide ticket open or close events.
     23 * ''Ticket updates'' - display or hide ticket update events (if enabled by [TracIni#timeline-ticket_show_details-option "[timeline] ticket_show_details"]).
    2324 * ''Wiki changes'' — display or hide Wiki change events.
    2425
    25 See !TracIni's [wiki:TracIni#timeline-section "[timeline] section"] for timeline configuration options.
     26See !TracIni's [wiki:TracIni#timeline-section "[timeline] section"] for timeline configuration options. Plugins may provide additional filters for the timeline.
    2627
    2728== RSS Support ==
    3031
    3132----
    32 See also: TracGuide, TracIni, TracWiki, WikiFormatting, TracRss, TracNotification
     33See also: TracWiki, WikiFormatting, TracRss
