Changes between Version 1 and Version 2 of UsersWikiBufferCoast
11/27/12 17:36:22 (12 years ago)
spluque
  • TabularUnified UsersWikiBufferCoast
    v1 v2
    1 In morphology, the dilation operation followed erosion is an extremely useful technique that allows for the simplification of complex shapes.  For example, the technique can be used to produce a simplified coastline, where bays and fjords are ignored, and that can later be used as a mask for further operations.
     1In morphology, the dilation operation followed by erosion is an extremely useful technique that allows for the simplification of complex shapes.  For example, the technique can be used to [http://blog.opengeo.org/2010/11/22/removing-complexities produce a simplified coastline], where bays and fjords are ignored, and that can later be used as a mask for further operations. Below is an illustration of the process of this technique for simplifying the convoluted coastline of Newfoundland, Canada, using GSHHS.
     3At first glance, it would seem that simply using one of the lower resolution coastline datasets from GSHHS would achieve the same result, but they were generated using a different procedure, which is not equivalent.
     5= Import GSHHS polygons into PostGIS =
     7[ftp://ftp.soest.hawaii.edu/pwessel/gshhs/GSHHS_shp_2.2.0.zip GSHHS shapefiles] provided by the maintainers can be imported into a PostGIS database (named gshhs here) using:
     8
     9{{{
     10shp2pgsql -s 4326 -I -g geom GSHHS_f_L1.shp gshhs_f_l1 | psql -d gshhs
     11}}}
     12
     13= Subset coastlines =
     14
     15Before performing any dilation/erosion, it is helpful to subset the coastline polygons for efficiency purposes.  The {{{gid}}} field in the table holding the GSHHS data identifies a single polygon.  The island of Newfoundland has {{{gid=23}}}:
     16
     17{{{
     18CREATE OR REPLACE VIEW newfoundland_subset_f
     19SELECT gshhs_f_l1.gid, gshhs_f_l1.geom
     20   FROM gshhs_f_l1
     21  WHERE gshhs_f_l1.gid = 23;
     22}}}
     23
     24= Dilation and erosion =
     25
     26PostGIS can perform these two operations via {{{ST_Buffer}}}.  For the purposes outlined here, the process involves buffering positively (dilating) the full resolution coastline by a given amount {{{k}}}, and then buffering the result negatively (eroding) by the same amount.  The following shell script applies the technique using different values for {{{k}}}.  It uses the utility {{{ogr2ogr}}} to export the PostGIS objects to an ASCII table in GMT (Generic Mapping Tools) format:
     27
     28{{{
     29PREFIX="newfoundland"
     30COAST="newfoundland_subset_f.gmt"
     31BUFOUT="newfoundland_subset_f_bufout"
     32BUFIN="newfoundland_subset_f_bufin"
     34ogr2ogr -f GMT ${COAST} \
     35    PG:"host=localhost user=username password=password dbname=gshhs" \
     36    ${COAST%%.gmt}
     37for buf in ${BUFFERS[@]}; do
     38    cat <<EOF > ${GMT_TMPDIR}/buffers.sql
     39    CREATE OR REPLACE VIEW ${COAST%%.gmt}_bufout AS
     40    SELECT gid, ST_Buffer(geom, ${buf}) FROM ${COAST%%.gmt};
     41    CREATE OR REPLACE VIEW ${COAST%%.gmt}_bufin AS
     42    SELECT gid, ST_Buffer(st_buffer, -${buf}) FROM ${COAST%%.gmt}_bufout;
     43EOF
     44    psql -f ${GMT_TMPDIR}/buffers.sql gshhs
     45    ogr2ogr -f GMT ${COAST%%.gmt}_bufout${buf}.gmt \
     46        PG:"host=localhost user=username password=password dbname=gshhs" \
     47        ${COAST%%.gmt}_bufout
     48    ogr2ogr -f GMT ${COAST%%.gmt}_bufin${buf}.gmt \
     49        PG:"host=localhost user=username password=password dbname=gshhs" \
     50        ${COAST%%.gmt}_bufin
     51done
     52}}}
     53
     54The animated {{{GIF}}} image below illustrates the results.
