Changes between Initial Version and Version 1 of UsersWikiCascadeUnion
04/15/09 08:25:13 (16 years ago)
pracine
  • TabularUnified UsersWikiCascadeUnion
     1The Pseudo Cascade Union aggregate function is intended as a drop in replacement
     2for the current PostGIS ST_Union aggregate function.  It should work in PostGIS versions
     31.2.2 -- 1.3.4.  Although I have only tested on 1.3.3 and 1.3.4SVN.  Seems to work in general 5-10 times faster than built in ST_Union, but I haven't really hammered it to ensure
     4it achieves the desired result in all cases.
     6In general I have found it to be 5-10 times faster than the built-in ST_Union aggregate function and also it finishes to completion in many cases where the built-in one runs out of memory.
     8The code can be downloaded from [http://www.bostongis.com/downloads/upgis_cascadeunion_functions_plpgsql.zip | http://www.bostongis.com/downloads/upgis_cascadeunion_functions_plpgsql.zip]
     10It is loosely based on the concepts used in JTS 1.9 Union Operator (aka Cascaded Union) which is described at
     12[http://lin-ear-th-inking.blogspot.com/2007/11/fast-polygon-merging-in-jts-using.html | http://lin-ear-th-inking.blogspot.com/2007/11/fast-polygon-merging-in-jts-using.html]
     13
     14Example use:
     15
     16This completes in 47,578 ms = 0.75 minutes
     17
     18
     19{{{
     20  SELECT state, upgis_cascadeunion(the_geom) as new_geom,
     21   SUM(ST_NPoints(the_geom)) As  numpointsbefore,
     22     ST_NPoints(upgis_cascadeunion(the_geom)) As numpointsafter
     23   FROM usstatebounds
     24   GROUP BY state
     25   ORDER BY state;
     27}}}
     28
     29
     30vs. Original ST_Union version - 830,625 (13.8 minutes)
     31
     32{{{
     34  SELECT state, ST_Union(the_geom) as the_geom,
     35   SUM(ST_NPoints(the_geom)) As  numpointsbefore,
     36     ST_NPoints(ST_Union(the_geom)) As numpointsafter
     37   FROM usstatebounds
     38   GROUP BY state
     39   ORDER BY state;
     40
     41}}}
