| 11 | == Coverages are Equations == |
| 12 | |
| 13 | The most fundamental thing which is true of all coverages is that they act like equations. More precisely, they act like mathematical functions. They calculate, lookup, interpolate, or return one or more values given a location and/or a time. Like mathematical functions, they may be defined everywhere (''for all values'') or only in certain places (e.g., only over land). The area over which a coverage is defined is the ''domain'' of that coverage. The set of values a coverage may return is the ''range'' of that coverage. This terminology is borrowed from mathematical equations. |
| 14 | |
| 15 | In general, the ''range'' of a coverage is not restricted to numbers. Given a location, for instance, a "nations" coverage may return a country name which contains that location. This is a common use. The ''range'' of a coverage is not necessarily restricted to "primitive" types either: it can even return another spatial type. This will become important later. The only constraint is that a coverage has the same ''range'' (or set of potential values from which an answer may be drawn) everywhere it is defined. If it returns a "County Name" and a "Population" in one place, it returns a "County Name" and a "Population" everywhere it is defined. |
| 16 | |
| 17 | Finally, ''most'' (but not all) coverages may be inverted. Using the above example, users may ask for the set of all locations where "County Name" is "Mineral", or "Population" is 20000. |
| 18 | |
| 19 | Querying a coverage for a set of values given a location is called ''evaluating'' the coverage. Querying for a (set of) location(s) given some criteria on the values is given the name ''evaluateInverse'' by ISO 19123. The specifics of how answers are generated for these queries depends on the type of coverage and how the "supporting data" are stored. |
| 20 | |
| 21 | == Continuous Coverages == |
| 22 | |
| 23 | Continuous coverages |
