Changes between Version 15 and Version 16 of UsersWikiPostGIS20Debian60pkg
10/25/12 18:57:40 (12 years ago)
danielceregatti
  • UsersWikiPostGIS20Debian60pkg
    v15 v16
    8989Download the two patch files from this page into the scratch directory.
    9090
    91 Build Postgis 2.0. This uses the postgis 1.5.3 control files from squeeze. The two patches are applied here to fix an issue with Postgis itself (a bad URL in java/jdbc/build.xml to the maven jar that ant requires for building), and to make the control files build the package. Ensure that both postgis_debian-2.0.1.patch and postgis_maven.patch are in the scratch directory.
     91Build Postgis 2.0. This uses the postgis 1.5.3 control files from squeeze. The two patches are applied here to fix an issue with Postgis itself (a bad URL in java/jdbc/build.xml to the maven jar that ant requires for building), and to make the control files build the package.
    9292{{{
    9393wget http://postgis.org/download/postgis-2.0.1.tar.gz
     94wget http://trac.osgeo.org/postgis/raw-attachment/wiki/UsersWikiPostGIS20Debian60pkg/postgis_debian-2.0.1.patch
    9495tar xvf postgis-2.0.1.tar.gz
    9596cd postgis-2.0.1
