Changes between Version 20 and Version 21 of UsersWikiPostGIS21UbuntuPGSQL93Apt
- 06/21/15 14:39:22 (10 years ago)
v20 v21 77 77 78 78 Find out where core files are located. 79 You may need to edit to pg_hba.conf and/or pg_ident.conf to allow external access - for example if you need external access, may add a line79 You may need to edit to pg_hba.conf and/or pg_ident.conf, postgresql.conf to allow external access - for example if you need external access, may add a line 80 80 like this to allow all with md5 password encrypt authentication (right after the local rules) 81 81 82 82 {{{ 83 host all all 0.0.0.0/0 md584 }}} 85 86 Make sure to do a: 83 hostssl all all 0.0.0.0/0 md5 84 }}} 85 86 You'll also want to edit the postgresql.conf file and change listen_addresses line to a specific ip of the server or '*' to listen on all ips. 87 87 88 88
