Changes between Version 6 and Version 7 of UsersWikiPostGIS21UbuntuPGSQL93Apt
- 08/08/14 16:11:28 (11 years ago)
v6 v7 4 4 (NOTE: These instructions do not work with Ubuntu 14.04 - finally got this to work for 14.04) 5 5 6 Run these in terminal: 7 == Verify what you are running == 8 {{{ 9 sudo lsb_release -a 10 }}} 11 12 6 13 == Add Respository to sources.list == 7 Verify what you are running:8 sudo lsb_release -a9 10 Run in terminal:11 14 12 15 You'll need to replace the nickname below with what you are running
