Changes between Initial Version and Version 1 of UsersWikiPostGIS23UbuntuPGSQL96Apt
03/25/17 09:23:02 (8 years ago)
robe
  • TabularUnified UsersWikiPostGIS23UbuntuPGSQL96Apt
     1The [http://wiki.postgresql.org/wiki/Apt PostgreSQL Apt Repository]  now hosts installs of PostGIS, pgRouting, in addition to Postgresql and PGAdmin3.
     3The following describes how to install Postgresql 9.5, PostGIS 2.2, pgRouting, PGAdmin on Ubuntu version 16.04. It is assumed to also work on Linux Mint, Lubuntu, and Xubuntu.
     5Run these in terminal:
     6== Verify what version of Ubuntu you are running ==
     7{{{
     8sudo lsb_release -a
     9}}}
     10
     12== Add Respository to sources.list ==
     13
     14You'll need to replace the nickname below with what you are running.
     15Note to replace the word trusty with whatever version lsb states
     16
     17Helper on [http://www.postgresql.org/download/linux/ubuntu/]
     18
     19For xenial (16.04.2 LTS)
     20
     21{{{
     22sudo sh -c 'echo "deb http://apt.postgresql.org/pub/repos/apt xenial-pgdg main" >> /etc/apt/sources.list'
     23}}}
     25
     26== Add Keys ==
     27{{{
     28wget --quiet -O - http://apt.postgresql.org/pub/repos/apt/ACCC4CF8.asc | sudo apt-key add -
     29}}}
     30
     31{{{
     32sudo apt-get update
     33}}}
     34
     35== Install ==
     36The following will install postgresql 9.6, PostGIS 2.3, PGAdmin4, pgRouting 2.3 and additional supplied modules including the '''adminpack''' extension:
     37
     38
     39{{{
     40sudo apt-get install postgresql-9.6
     41sudo apt-get install postgresql-9.6-postgis-2.3 postgresql-contrib-9.6
     42
     43#to get the commandline tools shp2pgsql, raster2pgsql you need to do this
     44sudo apt-get install postgis
     45}}}
     46
     47== To get pgRouting ==
     48{{{
     49# Install pgRouting 2.3 package
     50sudo apt-get install postgresql-9.6-pgrouting
     51
     52}}}
     53== Enable Adminpack ==
     54
     55While in terminal, log in to the psql console as postgres user:
     56
     57{{{
     58sudo -u postgres psql
     59}}}
     60
     61
     62
     63{{{
     64CREATE EXTENSION adminpack;
     65}}}
     66
     67
     68
     69Never install PostGIS in the postgres database, create a user database
     70You can also enable the PostGIS extension here (or with the GUI as described below):
     71
     72{{{
     73sudo -u postgres psql
     74}}}
     75
     76{{{
     77CREATE DATABASE gisdb;
     78\connect gisdb;
     79
     80CREATE SCHEMA postgis;
     81ALTER DATABASE gisdb SET search_path=public, postgis, contrib;
     82\connect gisdb;  -- this is to force new search path to take effect
     83CREATE EXTENSION postgis SCHEMA postgis;
     84SELECT postgis_full_version();
     85}}}
     86
     87should give you output something like this:
     88
     89
     90{{{
     91        postgis_full_version
     92---------------------------------------------------------------------------------------------------------------------------------------------------------------------------
     93 POSTGIS="2.3.2 r15302" GEOS="3.5.0-CAPI-1.9.0 r4084" PROJ="Rel. 4.9.2, 08 September 2015" GDAL="GDAL 1.11.3, released 2015/09/16" LIBXML="2.9.3" LIBJSON="0.11.99" RASTER
     94(1 row)
     95}}}
     96
     97Installing postgis_sfcgal, if you need advanced 3D support
     98
     100{{{
     101CREATE EXTENSION postgis_sfcgal SCHEMA postgis;
     102SELECT postgis_full_version();
     103}}}
     104
     105should give you:
     106
     107
     108{{{
     109        postgis_full_version
     110------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
     111 POSTGIS="2.3.2 r15302" GEOS="3.5.0-CAPI-1.9.0 r4084" SFCGAL="1.2.2" PROJ="Rel. 4.9.2, 08 September 2015" GDAL="GDAL 1.11.3, released 2015/09/16" LIBXML="2.9.3" LIBJSON="0.11.99" RASTER
     112(1 row)
     113}}}
     114
     115
     116
     117
     118Install pgRouting
     119
     120{{{
     121CREATE  EXTENSION pgrouting;
     122SELECT * FROM pgr_version();
     123}}}
     124
     125should give you:
     126
     127
     128{{{
     129 version |  tag   |   hash    | branch | boost
     130---------+--------+-----------+--------+--------
     131 2.3.2   | v2.3.2 | 1f2af3c52 | master | 1.58.0
     132(1 row)
     133}}}
     134
     135
     136
     137
     138Exit the psql console:
     139
     140{{{
     141\q
     142}}}
     143
     144
     145== Open Access to Clients ==
     146
     147If you need to allow access from external, you can do this as well
     148{{{
     149sudo -u postgres psql
     150}}}
     151
     152{{{
     153ALTER SYSTEM SET listen_addresses='*';
     154\q
     155}}}
     156
     157You may need to edit to pg_hba.conf and/or pg_ident.conf to allow external access
     158
     159{{{
     160sudo nano /etc/postgresql/9.6/main/pg_hba.conf
     161}}}
     162
     163If you need external access, scroll to the bottom of the pg_hba.conf file and add a line like this (which willa llow all clients with md5 password encrypt authentication (right after the local rules):
     164
     165{{{
     166hostssl    all             all             0.0.0.0/0               md5
     167}}}
     168
     169Click CTRL-X to save your changes, Y to write them to the file, and enter to exit.
     170
     171If you change ip or port, you need to do a service restart.
     172
     173{{{
     174sudo service postgresql restart
     175}}}
     176
     177Note: you can also do from postgres psql console with below - only for changes that don't require restart)
     178
     179{{{
     180SELECT pg_reload_conf();
     181}}}
     182
     183
     184== Optional: check location of configuration files: ==
     185
     186From the psql console(see above):
     187
     188{{{
     189SELECT name, setting FROM pg_settings where category='File Locations';
     190}}}
     191
     192Which will output something like:
     193
     194{{{
     195
     196       name        |                 setting
     197-------------------+------------------------------------------
     198 config_file       | /etc/postgresql/9.6/main/postgresql.conf
     199 data_directory    | /var/lib/postgresql/9.6/main
     200 external_pid_file | /var/run/postgresql/9.6-main.pid
     201 hba_file          | /etc/postgresql/9.6/main/pg_hba.conf
     202 ident_file        | /etc/postgresql/9.6/main/pg_ident.conf
     203(5 rows)
     204
     205}}}
     206
     207
     208
     209== Create new PGSQL user ==
     210
     211You can create a new database super user to use instead of the default {{{postgres}}} user.
     212
     213While in terminal, run:
     214
     215{{{
     216sudo su - postgres
     217}}}
     218
     219{{{
     220createuser -d -E -i -l -P -r -s yourUserName
     221}}}
     222
     223(be sure to change the username to your desired username)
     224
     225Enter your new password when prompted
     226
     227Log out as {{{postgres}}} user:
     228
     229{{{
     230exit
     231}}}
     232
     233Exit terminal:
     234
     235{{{
     236exit
     237}}}
     238
     239
     240
     241== Import SHP files using shp2pgsql-gui ==
     242
     243Another handy piece of software {{{shp2pgsql-gui}}} tool. This will allow you to quickly connect to your new PostGIS database and import a Shapefile.
     244
     245Open terminal, and type:
     246
     247{{{
     248sudo apt-get install postgis-gui
     249}}}
     250
     251(Note: this is coming from the main Ubuntu software repository, as it seems the PostgreSQL APT repository doesn't package SHP2PGSQL-GUI anymore...)
     252
     253Now open the SHP2PGSQL application:
     254
     255{{{
     256shp2pgsql-gui
     257}}}
     258
     259Follow the on-screen prompts to load your data.
     260
     261For more information, visit the [http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgis_tut01 Boston GIS] tutorial in the section "Load Towns Data"
     262
