Changes between Version 20 and Version 21 of UsersWikiPostgisTopology
03/12/17 04:04:33 (8 years ago)
strk
add more info about QGIS support
  • UsersWikiPostgisTopology
    v20 v21
    107107Table 2 : topo_test.rein_konsesjonomr_flate_v with attributtes from table one and a geometry columns casted from the portgis topology column. [[BR]]
    108108
    109 To check out the data use for instance qgis with Plugin: PostGIS Topology Editor from Strk .
     109To check out the data use for instance QGIS with the DBManager Plugin (select the topology schema and pick TopoViewer from the menu). You can also edit the primitive elements with the PostGIS Topology Editor from Strk (https://plugins.qgis.org/plugins/pgtopoeditor/)
    110110
    111111if you have some shape files added here som you can test here is a example where I uses shp2pgsl to gether with this script.
