Changes between Version 139 and Version 140 of UsersWikiPostgreSQLPostGIS
06/05/18 05:34:13 (7 years ago)
komzpa
Fix GEOS matrix
  • TabularUnified UsersWikiPostgreSQLPostGIS
    v139 v140
    5656GEOS 3.6.0 came out after 2.3.0 release, so most 2.3 distros will not have enabled - [http://postgis.net/docs/manual-2.3/ST_MinimumClearance.html ST_MinimumClearance*] that require 3.6, but may in 2.3.1
    5757
    58 ||'''Geos Version'''||'''PostGIS 1.3 EOL'''||'''PostGIS 1.4 EOL'''||'''PostGIS 1.5 EOL'''||'''PostGIS 2.0 EOL'''||'''PostGIS 2.1 EOL'''||'''PostGIS 2.2'''||'''PostGIS 2.3'''||'''PostGIS 2.4'''
    59 ||'''None'''||Yes (not recommended)||No||No||No||No||No||No
    60 ||'''2.2 EOL'''||Yes (not recommended)||No||No||No||No||No||No||No
    61 ||'''3.0 EOL'''||Yes||Yes (not recommended)||No||No||No||No||No||No
    62 ||'''3.1 EOL'''||Yes||Yes||Yes (not recommended) (requires 3.1.1+)||No||No||No||No||No
    63 ||'''3.2 EOL'''||Yes||Yes||Yes||Yes (not recommended)||No||No||No||No
    64 ||'''3.3 EOL'''||Yes||Yes||Yes (preferred 3.3.3+)||Yes (3.3.9+)||Yes (not recommended)||Yes*||No||No
    65 ||'''3.4'''||Yes||Yes||Yes (preferred 3.4.2+)||Yes (3.4.2+)||Yes||Yes*||Yes*||Yes*
    66 ||'''3.5'''||Yes||Yes||Yes||Yes||Yes||'''Yes''' (recommended)||Yes*||Yes*
    67 ||'''3.6'''||Yes||Yes||Yes||Yes||Yes||'''Yes'''||'''Yes''' (recommended)||'''Yes'''
    68 ||'''3.7*'''||Yes||Yes||Yes||Yes||Yes||'''Yes'''||'''Yes'''||'''Yes'''
     58||'''Geos Version'''||'''PostGIS 1.3 EOL'''||'''PostGIS 1.4 EOL'''||'''PostGIS 1.5 EOL'''||'''PostGIS 2.0 EOL'''||'''PostGIS 2.1 EOL'''||'''PostGIS 2.2'''||'''PostGIS 2.3'''||'''PostGIS 2.4'''|'''PostGIS 2.5'''
     59||'''None'''||Yes (not recommended)||No||No||No||No||No||No||No
     60||'''2.2 EOL'''||Yes (not recommended)||No||No||No||No||No||No||No||No
     61||'''3.0 EOL'''||Yes||Yes (not recommended)||No||No||No||No||No||No||No
     62||'''3.1 EOL'''||Yes||Yes||Yes (not recommended) (requires 3.1.1+)||No||No||No||No||No||No
     63||'''3.2 EOL'''||Yes||Yes||Yes||Yes (not recommended)||No||No||No||No||No
     64||'''3.3 EOL'''||Yes||Yes||Yes (preferred 3.3.3+)||Yes (3.3.9+)||Yes (not recommended)||Yes*||No||No||No
     65||'''3.4'''||Yes||Yes||Yes (preferred 3.4.2+)||Yes (3.4.2+)||Yes||Yes*||Yes*||Yes*||No
     66||'''3.5'''||Yes||Yes||Yes||Yes||Yes||'''Yes''' (recommended)||Yes*||Yes*||Yes*
     67||'''3.6'''||Yes||Yes||Yes||Yes||Yes||'''Yes'''||'''Yes''' (recommended)||Yes*||Yes*
     68||'''3.7*'''||Yes||Yes||Yes||Yes||Yes||'''Yes'''||'''Yes'''||'''Yes'''||'''Yes'''
    6969
    7070'''Versions of GDAL support for PostGIS'''
