Changes between Version 159 and Version 160 of UsersWikiPostgreSQLPostGIS
07/30/19 22:11:39 (6 years ago)
komzpa
  • UsersWikiPostgreSQLPostGIS
    v159 v160
    105105Thanks https://repology.org/ for badges.
    106106
    107 ||'''PostGIS''' || '''PostgreSQL''' || '''GEOS''' || '''GDAL''' || '''SFCGAL''' || '''Proj'''
    108 || [[Image(https://repology.org/badge/vertical-allrepos/postgis.svg?header=&minversion=2.3)]] || [[Image(https://repology.org/badge/vertical-allrepos/postgresql.svg?header=&minversion=9.5)]] || [[Image(https://repology.org/badge/vertical-allrepos/geos.svg?header=&minversion=3.7)]] || [[Image(https://repology.org/badge/vertical-allrepos/gdal.svg?header=&minversion=2.0)]] || [[Image(https://repology.org/badge/vertical-allrepos/sfcgal.svg?header=&minversion=1.3.6)]] ||[[Image(https://repology.org/badge/vertical-allrepos/proj.svg?header=&minversion=4.9)]]
     107||'''PostGIS''' || '''PostgreSQL''' || '''GEOS''' || '''GDAL''' || '''SFCGAL''' || '''Proj''' || '''protobuf-c'''
     108|| [[Image(https://repology.org/badge/vertical-allrepos/postgis.svg?header=&minversion=2.3)]] || [[Image(https://repology.org/badge/vertical-allrepos/postgresql.svg?header=&minversion=9.5)]] || [[Image(https://repology.org/badge/vertical-allrepos/geos.svg?header=&minversion=3.7)]] || [[Image(https://repology.org/badge/vertical-allrepos/gdal.svg?header=&minversion=2.0)]] || [[Image(https://repology.org/badge/vertical-allrepos/sfcgal.svg?header=&minversion=1.3.6)]] ||[[Image(https://repology.org/badge/vertical-allrepos/proj.svg?header=&minversion=4.9)]] ||[[Image(https://repology.org/badge/vertical-allrepos/protobuf-c.svg?header=&minversion=1.1.0)]]
