Changes between Version 208 and Version 209 of UsersWikiPostgreSQLPostGIS
07/08/22 08:12:05 (3 years ago)
robe
  • TabularUnified UsersWikiPostgreSQLPostGIS
    v208 v209
    11= Current best =
    3 As of 10th June, 2022 these versions are latest and give you best stable feature coverage.
     3As of 8th July, 2022 these versions are latest and give you best stable feature coverage.
    44
    55 * PostGIS 3.2.1 [[Image(https://repology.org/badge/latest-versions/postgis.svg)]] https://postgis.net/2022/02/12/postgis-3.2.1/
    6  * PostgreSQL 14.3 [[Image(https://repology.org/badge/latest-versions/postgresql.svg)]] https://www.postgresql.org/docs/14/release-14-2.html
    7  * GEOS 3.10.3 [[Image(https://repology.org/badge/latest-versions/geos.svg)]] https://github.com/libgeos/geos/blob/main/NEWS
     6 * PostgreSQL 14.4 [[Image(https://repology.org/badge/latest-versions/postgresql.svg)]] https://www.postgresql.org/docs/14/release-14-2.html
     7 * GEOS 3.11.0 [[Image(https://repology.org/badge/latest-versions/geos.svg)]] https://github.com/libgeos/geos/blob/main/NEWS
    88 * SFCGAL 1.4.1 [[Image(https://repology.org/badge/latest-versions/sfcgal.svg)]] https://gitlab.com/Oslandia/SFCGAL/-/releases
    9  * GDAL 3.5.0 [[Image(https://repology.org/badge/latest-versions/gdal.svg)]] https://github.com/OSGeo/gdal/releases
    10  * PROJ 8.2.1 [[Image(https://repology.org/badge/latest-versions/proj.svg)]] https://github.com/OSGeo/PROJ/releases
     9 * GDAL 3.5.1 [[Image(https://repology.org/badge/latest-versions/gdal.svg)]] https://github.com/OSGeo/gdal/releases
     10 * PROJ 9.0.1 [[Image(https://repology.org/badge/latest-versions/proj.svg)]] https://github.com/OSGeo/PROJ/releases
    1111 * protobuf-c 1.4.0 [[Image(https://repology.org/badge/latest-versions/protobuf-c.svg)]] https://github.com/protobuf-c/protobuf-c/releases
    1212 * json-c 0.16 [[Image(https://repology.org/badge/latest-versions/json-c.svg)]] https://github.com/json-c/json-c
