Changes between Version 8 and Version 9 of UsersWikiPostgreSQLPostGIS
10/30/09 10:34:10 (15 years ago)
robe
  • TabularUnified UsersWikiPostgreSQLPostGIS
    v8 v9
    1212
    1313'''Versions of GEOS vs of PostGIS'''
     14The below chart shows which versions of GEOS work with which versions of PostGIS.
     15The none means that you can get that version to work without GEOS, though its not recommended since a lot of functions will not be installed.
     16
     17For the not recommended, this means that while you can get PostGIS to work with those versions, you'll be missing out on some PostGIS functions such as ST_Covers, ST_CoversBy and for PostGIS 1.5 the HausdorDistance and enhancements to ST_Buffer (both speed and functionality)
    1418||'''Geos Version'''||'''PostGIS 1.3'''||'''PostGIS 1.4'''||'''PostGIS 1.5'''||
    1519||'''None'''||Yes (not recommended)||No||No||
