Changes between Version 97 and Version 98 of UsersWikiPostgreSQLPostGIS
- 10/27/16 12:31:30 (8 years ago)
v97 v98 52 52 For the not recommended, this means that while you can get PostGIS to work with those versions, you'll be missing out on some PostGIS functions such as ST_Covers, ST_CoversBy and for PostGIS 1.5 the ST_HausdorffDistance and enhancements to ST_Buffer (both speed and functionality). GEOS 3.1 brought cascade union. GEOS 3.2 brought faster buffering and buffering enhancements, plus numerous enhancements with dealing with tolerance issues when unioning. GEOS 3.3 brought ST_ValidReason, ST_MakeValid etc (in the PostGIS 2.0 releases), so these functions will be disabled in PostGIS 2.0 if you are not running GEOS 3.3. GEOS 3.3. also brought stability fixes for union/buffer not back-ported to 3.2. For PostGIS 1.5, although 3.3 does not add any additional functions, it does fix some crashers involving buffering and unioning not present in other minor releases, so suggested to use that if you can. 53 53 54 GEOS 3.4 introduced interruptibility features that allow you to cancel a query while in a GEOS loops. Prior versions of PostGIS/GEOS a query could run (even with statement timeout) until you ran out of memory. This new feature requires both PostGIS 2.1 and GEOS 3.4+. 3.4 also brought [http://www.postgis.org/documentation/manual-svn/ST_DelaunayTriangles.html ST_DelaunayTriangles] so you won't get that in 2.1 if you don't compile for 3.4+. 54 GEOS 3.4 introduced interruptibility features that allow you to cancel a query while in a GEOS loops. Prior versions of PostGIS/GEOS a query could run (even with statement timeout) until you ran out of memory. This new feature requires both PostGIS 2.1+ and GEOS 3.4+. 3.4 also brought [http://postgis.net/docs/manual-2.1/ST_DelaunayTriangles.html ST_DelaunayTriangles] so you won't get that in 2.1 if you don't compile for 3.4+. 55 GEOS 3.5 brought some enhancements needed new features in PostGIS 2.2 [http://postgis.net/docs/manual-2.2/ST_Subdivide.html ST_Subdivide] and [http://postgis.net/docs/manual-2.2/ST_ClipByBox2D.html ST_ClipByBox2D] 56 GEOS 3.5 also brought ST_Voronoi so if compiled with lower than 3.5, the ST_Voronoi introduced in PostGIS 2.3 won't be available [http://postgis.net/docs/manual-2.3/ST_VoronoiLines.html ST_VoronoiLines and ST_VoronoiPolygons]. 57 GEOS 3.6.0 came out after 2.3.0 release, so most 2.3 distros will not have enabled - [http://postgis.net/docs/manual-2.3/ST_MinimumClearanceLine.html ST_MinimumClearance*] that require 3.6, but may in 2.3.1 55 58 56 ||'''Geos Version'''||'''PostGIS 1.3'''||'''PostGIS 1.4'''||'''PostGIS 1.5'''||'''PostGIS 2.0'''||'''PostGIS 2.1'''||'''PostGIS 2.2'''||'''PostGIS 2.3 Trunk'''59 ||'''Geos Version'''||'''PostGIS 1.3'''||'''PostGIS 1.4'''||'''PostGIS 1.5'''||'''PostGIS 2.0'''||'''PostGIS 2.1'''||'''PostGIS 2.2'''||'''PostGIS 2.3'''||'''PostGIS 2.4 (Trunk)''' 57 60 ||'''None'''||Yes (not recommended)||No||No|| No|| No|| No|| No 58 ||'''2.2'''||Yes (not recommended)||No||No|| No|| No|| No|| No 59 ||'''3.0'''||Yes||Yes (not recommended)||No|| No|| No|| No|| No 60 ||'''3.1'''||Yes||Yes||Yes (not recommended) (requires 3.1.1+)|| No|| No|| No|| No 61 ||'''3.2'''||Yes||Yes||Yes||Yes (not recommended)|| No|| No|| No 62 ||'''3.3'''||Yes||Yes||Yes (preferred 3.3.3+)||Yes (3.3.9+)|| Yes (not recommended)|| Yes*|| No* 63 ||'''3.4'''||Yes||Yes||Yes (preferred 3.4.2+)||Yes (3.4.2+)|| Yes|| Yes*|| Yes* 64 ||'''3.5*'''||Yes||Yes||Yes ||Yes|| Yes|| Yes (recommended) || Yes 61 ||'''2.2'''||Yes (not recommended)||No||No|| No|| No|| No|| No|| No 62 ||'''3.0'''||Yes||Yes (not recommended)||No|| No|| No|| No|| No|| No 63 ||'''3.1'''||Yes||Yes||Yes (not recommended) (requires 3.1.1+)|| No|| No|| No|| No|| No 64 ||'''3.2'''||Yes||Yes||Yes||Yes (not recommended)|| No|| No|| No|| No 65 ||'''3.3'''||Yes||Yes||Yes (preferred 3.3.3+)||Yes (3.3.9+)|| Yes (not recommended)|| Yes*|| No || No 66 ||'''3.4'''||Yes||Yes||Yes (preferred 3.4.2+)||Yes (3.4.2+)|| Yes|| Yes*|| Yes* || Yes* 67 ||'''3.5'''||Yes||Yes||Yes ||Yes|| Yes|| Yes (recommended) || Yes* || Yes* 68 ||'''3.6'''||Yes||Yes||Yes ||Yes|| Yes|| Yes || Yes (recommended) || Yes 69 ||'''3.7*'''||Yes||Yes||Yes ||Yes|| Yes|| Yes || Yes || Yes 65 70 66 71 '''Versions of GDAL support for PostGIS''' 67 72 PostGIS raster functionality (introduced in 2.0) depends on GDAL so to get raster functionality, you'll need to compile with GDAL support and preferrably 68 73 1.9 or above. Although you can compile PostGIS 2.0 without raster support, you really should rethink that decision, especially if you are a package maintainer (you'll have a lot of pissed off users if you do :)). For PostgreSQL 9.1 extension support, compiling with raster support is ABSOLUTELY required since the postgis extension includes the raster functionality. * Means it currently does or doesn't but may change at release time. 69 PostGIS 2.2 has ST_ClipByBox2D and ST_SubDivide which require GEOS 3.570 74 71 ||'''GDAL Version'''||'''Pre - PostGIS 2.0'''||'''PostGIS 2.0'''||'''PostGIS 2.1'''||'''PostGIS 2.2'''||'''PostGIS 2.3 Trunk''' 75 76 ||'''GDAL Version'''||'''Pre - PostGIS 2.0'''||'''PostGIS 2.0'''||'''PostGIS 2.1'''||'''PostGIS 2.2'''||'''PostGIS 2.3'''||'''PostGIS 2.3 Trunk''' 72 77 ||'''1.7'''||N/A||Yes (not recommended)||No||No||No 73 78 ||'''1.8'''||N/A||Yes (not recommended)||Yes (not recommended)||Yes*||Yes* … … 75 80 ||'''1.10'''||N/A||Yes||Yes||Yes||Yes 76 81 ||'''1.11'''||N/A||Yes||Yes||Yes||Yes 77 ||'''2.0'''||N/A||No||No||Yes||Yes 82 ||'''2.0'''||N/A||No||No||Yes||Yes||Yes 83 ||'''2.1'''||N/A||No||No||Yes||Yes||Yes
