Changes between Version 16 and Version 17 of UsersWikiSimplifyPreserveTopology
04/09/12 11:03:58 (13 years ago)
nicolasribotosgeo
  • TabularUnified UsersWikiSimplifyPreserveTopology
    v16 v17
    104104 [[Image(SPT_bad_attributes.png)]]
    105105
    106 8. Second method is based on percentage of overlaping area comparison.
    107 {{{
    108 #!sql
     1068. Second method is based on percentage of overlaping area comparison. Empirical ratio used here.
     107{{{
     108#!sql
     109
    109110create table simpledep as (
    110         select distinct on (d.code_dept) d.code_dept, s.g as geom
     111        select d.code_dept, s.g as geom
    111112        from departement d, simplepolys s
    112113        where st_intersects(d.geom, s.g)
    113         order by d.code_dept, st_area(st_intersection(s.g, d.geom))/st_area(s.g) desc
     114        and st_area(st_intersection(s.g, d.geom))/st_area(s.g) > 0.5
    114115);
    115116}}}
    148149        select gid, code_dept, (st_dump(geom)).*
    149150        from departement
    150 ) select distinct on (d.code_dept) d.code_dept, baz.geom
     151) select d.code_dept, baz.geom
    151152 from (
    152153        select (st_dump(st_polygonize(distinct geom))).geom as geom
    161162poly d
    162163where st_intersects(d.geom, baz.geom)
    163 order by d.code_dept, st_area(st_intersection(baz.geom, d.geom))/st_area(baz.geom) desc;
     164and st_area(st_intersection(d.g, baz.geom))/st_area(baz.g) > 0.5;
    164165}}}
    165166
    178179        tol alias for $4;
    179180        numpoints int:=0;
     181        time text:='';
    180182
    181183    BEGIN
    182184
    183         EXECUTE 'select sum(st_npoints(geom)) from '||quote_ident(tabname) into numpoints;
    184         raise notice 'Num points in %: %', tabname, numpoints;
     185        EXECUTE 'select sum(st_npoints(geom)), to_char(clock_timestamp(), ''MI:ss:MS'') from '||quote_ident(tabname) into numpoints, time;
     186        raise notice 'Num points in %: %. Time: %', tabname, numpoints, time;
    185187
    186188        EXECUTE 'create unlogged table poly as ('
    191193        select st_exteriorRing((st_dumpRings(geom)).geom) as g from poly;
    192194
    193         raise notice 'rings created...';
     195        select to_char(clock_timestamp(), 'MI:ss:MS') into time;
     196        raise notice 'rings created: %', time;
    194197
    195198        drop table poly;
    196199
    197200        -- Simplify the rings. Here, no points further than 10km:
    198         create unlogged table simplerings as select st_simplifyPreserveTopology(st_linemerge(st_union(g)), tol) as g from rings;
    199
    200         raise notice 'rings simplified...';
     201        create unlogged table gunion as select st_union(g) as g from rings;
     202
     203        select to_char(clock_timestamp(), 'MI:ss:MS') into time;
     204        raise notice 'union done: %', time;
    201205
    202206        drop table rings;
     207
     208        create unlogged table mergedrings as select st_linemerge(g) as g from gunion;
     209
     210        select to_char(clock_timestamp(), 'MI:ss:MS') into time;
     211        raise notice 'linemerge done: %', time;
     212
     213        drop table gunion;
     214
     215        create unlogged table simplerings as select st_simplifyPreserveTopology(g, tol) as g from mergedrings;
     216
     217
     218        select to_char(clock_timestamp(), 'MI:ss:MS') into time;
     219        raise notice 'rings simplified: %', time;
     220
     221        drop table mergedrings;
    203222
    204223        -- extract lines as individual objects, in order to rebuild polygons from these
    216235
    217236        select count(*) from simplepolys into numpoints;
    218
    219         raise notice 'rings polygonized. num rings: %', numpoints;
     237        select to_char(clock_timestamp(), 'MI:ss:MS') into time;
     238        raise notice 'rings polygonized. num rings: %. time: %', numpoints, time;
    220239
    221240        drop table simplelines;
    226245        raise notice 'spatial index created...';
    227246
    228         -- comparing percentage of overlaping area gives good results to identify simplified objects.
    229         -- (the 50% of overlapping area is empirical. Should fail with some odd-shaped polygons)
     247        -- works better: comparing percentage of overlaping area gives better results.
     248        -- as input set is multipolygon, we first explode multipolygons into their polygons, to
     249        -- be able to find islands and set them the right departement code.
    230250        RETURN QUERY EXECUTE 'select '||quote_ident(tid)||', st_collect(geom) as geom '
    231251            ||'from ('
    235255            ||'    where st_intersects(d.'||quote_ident(geo)||', s.g) '
    236256            ||'    and st_area(st_intersection(s.g, d.'||quote_ident(geo)||'))/st_area(s.g) > 0.5 '
    237             ||'    order by d.'||quote_ident(tid)||', st_area(st_intersection(s.g, d.'||quote_ident(geo)||'))/st_area(s.g) desc '
    238257            ||'    ) as foo '
    239258            ||'group by '||quote_ident(tid);
