Changes between Version 105 and Version 106 of UsersWikiWinCompile
12/11/09 11:35:37 (15 years ago)
pracine
  • TabularUnified UsersWikiWinCompile
    v105 v106
    291291# make check
    292292}}}
    293 For the "make check" to work the server must be accepting connection on port 5432 (the default) and your Windows account must be recognized as a role in the database.
     293For the "make check" to work the server must be running and accepting connections on port 5432 (the default) and your Windows account must be recognized as a role in the database.
    294294
    295295If you run into problems with your build, pipe the output into a file for further analysis. The GUI requires that pkg-config be on your PATH, check that it is there by running 'which pkg-config'.
