Changes between Version 58 and Version 59 of UsersWikiWinCompile
07/16/09 18:34:24 (16 years ago)
robe
  • TabularUnified UsersWikiWinCompile
    v58 v59
    145145      1. ''cd /c/thesrc/postgresql-8.3.7'' (the version of today)
    146146      2. ''configure --prefix=/c/postgres && make && make install''
    147   3.  If you want to be able to do a full make check on PostGIS, [ UserWikiWinCompileInitPG you will need to initialize the db cluster]
     147  3.  If you want to be able to do a full make check on PostGIS, [UserWikiWinCompileInitPG you will need to initialize the db cluster]
    148148
    149149note that we now have changed the install-directory from mingw to postgres
