Changes between Version 28 and Version 29 of UsersWikiWinCompileInitdb
- 12/09/09 07:07:52 (15 years ago)
v28 v29 16 16 a. You can uninstall the service with:[[BR]][[BR]] "c:\postgres\bin\pg_ctl" unregister -N "pgsql-8.3 test" (this requires a restart)[[BR]][[BR]]A faster way is to stop the service and then from dos:[[BR]][[BR]]sc delete "pgsql-8.3 test" 17 17 18 6. Before you do a make check for PostGIS 19 -- make sure to do an export of PGPORT and other variable to point to the one you are testing (this you do in Msys) 18 6. Before you do a make check for PostGIS 19 20 * make sure to do an export of PGPORT and other variable to point to the one you are testing (this you do in Msys) 20 21 http://www.postgresql.org/docs/8.3/interactive/libpq-envars.html 21 22
