Changes between Version 22 and Version 23 of UsersWikiWinUpgrade
04/01/13 04:46:25 (12 years ago)
robe
  • TabularUnified UsersWikiWinUpgrade
    v22 v23
    4040
    41415. Edit the script accordingly to your path settings.  Note that utils folder is packaged with the PostGIS tar balls
    42 if not present in your PostGIS install. Download the tar ball for the PostGIS you want to upgrade to and copy the utils folder to the same folder as your backup.  [http://www.postgis.org/download/]
     42if not present in your PostGIS install. Download the tar ball for the PostGIS you want to upgrade to and copy the utils folder to the same folder as your backup.  [http://postgis.net/source]
    4343
    44446. Right mouse click on the .bat file (you may have to choose -- Run as Administrator) or run if run as administrator is not available.
