Changes between Version 2 and Version 3 of UsersWikiWinUpgrade
- 12/20/11 08:36:07 (13 years ago)
UsersWikiWinUpgrade
v2 v3 37 37 5. Edit the script accordingly to your path settings. Note that utils folder is packaged with the PostGIS tar balls 38 38 if not present in your PostGIS install. Download the tar ball for the PostGIS you want to upgrade too. [http://www.postgis.org/download/] 39 39 40 6. Right mouse click on the .bat file (you may have to choose -- Run as Administrator) 41 40 42 7. If all is working -- you should see a screen something like: 41 43
