Changes between Version 4 and Version 5 of UsersWikiWinUpgrade
12/20/11 08:37:11 (13 years ago)
robe
  • TabularUnified UsersWikiWinUpgrade
    v4 v5
    55or you are upgrading from one major version to another e.g 0.*, 1.* --> 2.*
    66
    7 1. Create a backup of your postgis database as usual.  You can do this with pg_dump as that instructions describe or pgadmin by right-clicking on the database -> Backup.  Make sure to use "Custom" backup for format if you are using !PgAdmin III.
     71. Create a backup of your postgis database as usual.  You can do this with pg_dump as that instructions describe or !PgAdmin by right-clicking on the database -> Backup.  Make sure to use "Custom" backup for format if you are using !PgAdmin III.
    882. Create a new postgis database installed with the postgis version you want to upgrade to.  Note if you are using PostgreSQL 9.1 and PostGIS 2.0 -- you can use the new in psql or pgAdmin III sql window after you have created a new database
    99to spatially enable it.
