Changes between Initial Version and Version 1 of UsersWikiWinVista
05/30/09 11:16:04 (16 years ago)
robe
  • UsersWikiWinVista
     1These instuctions are extracted from http://postgis.refractions.net/pipermail/postgis-users/2007-February/014782.html
     3The standard win32 installer of PostgreSQL fails on its own. There are
     4a some tricks needed to get through the new security measures in
     5Vista, but it can be done, and in the end it works fine.  Here's how:
     71. Turn off the Windows Vista User Account Contral (UAC). This is done
     8from Users in the Control Panel.
     102. Enable the Vista 'Administrator' user account. By default it is disabled.
     11- In the Start Menu, right click on Computer, select Manage
     12- In System Tools / Local Users and Groups / Users, open the
     13properties of the Administrator account and enable it. You will have
     14to assign a new password to the account.  Installation will not work
     15from a regular account with administrator rights, it must be this
     16master Administrator account.
     17
     183. Create a new standard limited user account called postgres. Give it
     19a password. The PostgreSQL installer can not create this account in
     20Vista so do it ahead of time yourself.
     21
     224. Login to the new Administrator account.
     23
     245. Install PostgreSQL from the windows msi installer file. Remember to
     25not install PostGIS at this point, you'll want the more upto date
     26version than wha tthe installer has.
     27- It will ask for the postgres username and password you created in step 3.
     28- Install as a Service
     29- DO NOT select to have the installer initialize a new database. It
     30will not work. postgres.exe protects you by not running when it has
     31administrator rights, if you try to have the installer initialize a
     32new database you will get an 'initdb failed' error message and the
     33installation will rollback. If you dig deeper it will tell you that
     34initdb can not find the postgres application even though it is present
     35in the bin directory.  It is there, it just won't run.
     36
     376. When the installer has finished successfully, logout of windows.
     38Log back in as the postgres user.
     39
     407. Open a command prompt, this is found in Accessories in the start
     41menue / All Programs.
     42
     438. Initialize a postgresql database.
     44- change to the C:\Program Files\PostgreSQL\8.2\bin directory
     45- run a command something like:
     46initdb -D "C:\Program FIles\PostgreSQL\8.2\data" -U postgres -E UTF8
     47
     489.  You should now have a working installation of PostgreSQL.  Install
     49PostGIS using the appropriate installer from www.refractions.net.
     50Remember to get the installer that is made for your version of
     51PostgreSQL.
     52
     5310. Disable the Administrator account and turn UAC back on.
     54
     5511. Profit!!
