Changes between Version 1 and Version 2 of UsersWikiwktrasterfunctions
05/02/10 20:19:35 (15 years ago)
robe
  • TabularUnified UsersWikiwktrasterfunctions
    v1 v2
    1 == WKT Raster User contributed Functions ==
    2 * This section contains additional functions not currently in WKT Raster.  Some of these may become obsolete as WKT Raster becomes more mature
     1= WKT Raster User contributed Functions =
     2* ''' This section contains additional functions not currently in WKT Raster.  Some of these may become obsolete as WKT Raster becomes more mature '''
     4{{{
     5#!sql
     6CREATE OR REPLACE FUNCTION upgis_ptval(param_rast raster, param_bnum integer, param_pt geometry)
     7 RETURNS float AS
     8  $$
     9  DECLARE
     10    var_result float = 0; var_rid integer;
     11    var_cols integer; var_rows integer;var_c integer;  var_r integer;
     12    var_upx float; var_upy float; var_sizex float; var_sizey float;
     13  BEGIN
     14  -- 1 does point intersects chosen tile
     15        SELECT ST_Width(param_rast), ST_Height(param_rast), ST_UpperLeftX(param_rast), ST_UpperLeftY(param_rast), ST_PixelSizeX(param_rast), ST_PixelSizeY(param_rast)
     16      INTO var_cols, var_rows, var_upx, var_upy, var_sizex, var_sizey
     17    WHERE ST_Intersects(ST_Envelope(param_rast), param_pt)
     18    LIMIT 1;
     19
     20   -- 2 if no return null
     21    IF var_cols IS NULL THEN -- doesn't intersect
     22      var_result := NULL;
     23    ELSE
     24   --  3 find row and column
     25    SELECT 1 + floor( ( (ST_X(param_pt) - var_upx) / (var_sizex*var_cols) )*var_cols )::integer, 1 + floor( ( (ST_Y(param_pt) - var_upy)/(var_sizey*var_rows) )*var_rows )::integer
     26      INTO var_c, var_r;
     27
     28   -- 4 edge case
     29      IF var_c = 0 THEN var_c := 1; END IF;
     30      IF var_r = 0 THEN var_r := 1; END IF;
     31      IF var_c = var_cols + 1 THEN var_c := var_cols; END IF;
     32      IF var_r = var_rows + 1 THEN var_r := var_rows; END IF;
     33   -- 5 get cell value
     34      SELECT ST_Value(param_rast,param_bnum, var_c , var_r )
     35        INTO var_result;
     36    END IF;
     37    --RAISE NOTICE 'col: %, row: %, val: %, pt: %', var_c, var_r, var_result, ST_AsText(param_pt);
     38    RETURN var_result;
     39  END
     40 $$
     41LANGUAGE 'plpgsql' IMMUTABLE;
     42COMMENT ON FUNCTION upgis_ptval(raster, integer, geometry) IS 'This function takes as input raster, band_num, point geometry and returns the band pixel value of the cell the point falls in.  It assumes the spatial reference system of the geometry and raster are the same.';
     43}}}
