Changes between Version 47 and Version 48 of WKTRaster/Documentation01
- 12/10/09 10:46:29 (15 years ago)
v47 v48 289 289 '''Regularly Blocked Table''' 290 290 291 You can inform PostGIS that the raster layer you are loading meets certain useful criteria by adding the –k option to the gdal2wktraster.py Python loader. This will set the "regular_blocking" attribute of the raster_columns table to '' ''true. It implies that:291 You can inform PostGIS that the raster layer you are loading meets certain useful criteria by adding the –k option to the gdal2wktraster.py Python loader. This will set the "regular_blocking" attribute of the raster_columns table to ''true''. It implies that: 292 292 293 293 1. All loaded tiles have the same width and height,[[BR]]
