Changes between Version 4 and Version 5 of WKTRaster/GDALDriverSpecificationWorking
- 02/17/11 14:00:54 (14 years ago)
v4 v5 23 23 * If the table has more than one row: the table must have been marked as "regularly blocked table", with -k in loader 24 24 25 * Able to producegenerate two kind of raster object based on two modes:25 * Able to generate two kind of raster object based on two modes: 26 26 - ONE_RASTER_PER_ROW ('mode = 1' in connection string, or nothing): The default mode. Each table row is considered as an independent raster. If the table required has more than one row, and no -where clause has been specified in connection string, all the table rows will be considered as reported as Subdatasets. Unless you specify the other working mode 27 27 - ONE_RASTER_PER_TABLE ('mode = 2' in connection string): Each table is considered as a raster coverage, and each row is a raster tile.
