Changes between Version 88 and Version 89 of WKTRaster/PlanningAndFunding
07/29/10 07:50:50 (15 years ago)
pracine
  • TabularUnified WKTRaster/PlanningAndFunding
    v88 v89
    9595||[[BR]]'''Objective 0.1.6f - Being able to return a JPEG, a TIFF or a PNG.''' ([wiki:WKTRaster/SpecificationWorking01#Objective0.1.6f-BeingabletoreturnaJPEGaTIFForaPNG. specifications])||||||||||
    9696||- ST_Band(raster, band) -> raster[[BR]]- ST_AsJPEG(raster, band, quality) -> JPEG as "bytea"[[BR]]- ST_AsTIFF(raster, band, compression) -> TIFF as "bytea"[[BR]]- ST_AsPNG(raster, band) -> PNG as "bytea"||ML||July - August 2010||TBD||2400 / !DevTime from ML||todo||
    97 ||[[BR]]'''Objective 0.1.6g - Being able to read in-db regular blocking WKT Raster with the GDAL driver. ''' ([wiki:WKTRaster/SpecificationWorking01#Objective0.1.6g-BeingabletoreadandwriteWKTRasterwithGDALdriver. specifications])||||||||||
    98 ||- Read a WKT Raster from database (in-db, regular blocking)||JA||July - August 2010||TBD||!DevTime from JA ||in-progress||
    9997||[[BR]]'''Objective 0.1.6h - Being able to set all the properties of a raster.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||||||||||
    10098||- ST_SetSRID(raster|geometry, integer)[[BR]]- ST_SetPixelSize(raster, pixelsizex, pixelsizey)[[BR]]- ST_SetBandNoDataValue(raster, band, nodatavalue)[[BR]]- ST_SetGeoReference(raster, string)[[BR]]- ST_SetSkew(raster, skewx, skewy)[[BR]]- ST_Rotation(raster)[[BR]]- ST_SetRotation(raster, rotation)[[BR]]- ST_SetUpperLeft(raster, x, y)||dzwarg||||1 week||Devtime from DZ||in-progress||
    101 ||[[BR]]'''Objective 0.1.6i - Being able to read out-db irregular blocking WKT Raster with the GDAL driver. ''' ([wiki:WKTRaster/SpecificationWorking01#Objective0.1.6g-BeingabletoreadandwriteWKTRasterwithGDALdriver. specifications])||||||||||
    102 ||- Read a WKT Raster from database (out-db, irregular blocking)||JA||July - August 2010||TBD||!DevTime from JA ||in-progress||
    103 ||[[BR]]'''Objective 0.1.6j - Being able to write WKT Raster with the GDAL driver. ''' ([wiki:WKTRaster/SpecificationWorking01#Objective0.1.6g-BeingabletoreadandwriteWKTRasterwithGDALdriver. specifications])||||||||||
    104 ||- Create a new WKT Raster in database (in-db/out-db, regular/irregular blocking)||JA||July - August 2010||TBD||!DevTime from JA ||in-progress||
    10599
    106100
    143137||- ST_SetValue(raster, band, x, y, value)[[BR]]- ST_Affine(raster|geometry,...) -> same type as input[[BR]]- ST_Translate(raster|geometry,...) -> same type as input[[BR]]- ST_Scale(raster|geometry,...) -> same type as input[[BR]]- ST_TransScale(raster|geometry,...) -> same type as input[[BR]]- ST_RotateZ,Y,Z(raster|geometry, float8) -> same type as input||TBD||||2 weeks||2400||todo||
    144138||Other functions[[BR]]- ST_AsBinary(raster, compression)[[BR]]- ST_RasterFromWKB(raster, [<srid>])[[BR]]- ST_RasterFromText(string, [<srid>])[[BR]]- ST_AsText(raster)|| ML (start ST_AsBinary) || Aug 2009||2 weeks||2400 / !DevTime from MD||in-progress||
    145 ||'''Total'''||||||48 weeks||58800||||
    146139
     140== GDAL Driver Milestones ==
     141
     142||'''Objectives and Tasks'''||'''Coder'''||'''Approx. Schedule'''||'''Time'''||'''Fund (US$)'''||'''Status'''||
     143||[[BR]]'''Objective 1 - Being able to read in-db regular blocking WKT Raster with the GDAL driver. ''' ([wiki:WKTRaster/SpecificationWorking01#Objective0.1.6g-BeingabletoreadandwriteWKTRasterwithGDALdriver. specifications])||||||||||
     144||- Read a WKT Raster from database (in-db, regular blocking)||JA||July - August 2010||TBD||!DevTime from JA ||in-progress||
     145||[[BR]]'''Objective 2 - Being able to read out-db irregular blocking WKT Raster with the GDAL driver. ''' ([wiki:WKTRaster/SpecificationWorking01#Objective0.1.6g-BeingabletoreadandwriteWKTRasterwithGDALdriver. specifications])||||||||||
     146||- Read a WKT Raster from database (out-db, irregular blocking)||JA||July - August 2010||TBD||!DevTime from JA ||in-progress||
     147||[[BR]]'''Objective 3 - Being able to write WKT Raster with the GDAL driver. ''' ([wiki:WKTRaster/SpecificationWorking01#Objective0.1.6g-BeingabletoreadandwriteWKTRasterwithGDALdriver. specifications])||||||||||
     148||- Create a new WKT Raster in database (in-db/out-db, regular/irregular blocking)||JA||July - August 2010||TBD||!DevTime from JA ||in-progress||
     149
