Changes between Version 24 and Version 25 of WKTRaster/SpecificationFinal01
08/27/10 11:51:11 (15 years ago)
pracine
  • TabularUnified WKTRaster/SpecificationFinal01
    v24 v25
    110110'''ST_BandNoDataValue(raster, integer) -> float32'''[[BR]]
    111111Return the !NoDataValue of the specified  1-based Nth band of raster. Band index is 1-based. The value is always returned as a float32 even if the pixel type is integer.
     112
     113----
     114== '''Objective 0.1.6e - Being able to intersect vector and raster to produce vector.''' ==
     115
     116List of PostGIS functions similar or related to ST_GetBBox(), ST_Envelope() and ST_Polygon():
     117
     118[http://postgis.refractions.net/documentation/manual-1.4/ST_Boundary.html ST_Boundary(geometry)] (not really - always return a geometry a dimension lower - i.e. the boundary of a polygon is a polyline.)
     119
     120ST_box(geometry) (return a PostgreSQL box object)
     121
     122[http://postgis.refractions.net/documentation/manual-1.4/ST_Box2D.html ST_box2d(geometry)] (return a box2d object)
     123
     124[http://postgis.refractions.net/documentation/manual-1.4/ST_Box3D.html ST_box3d(geometry)] (return a box3d object)
     125
     126getBBOX(geometry) (Deprecation in 1.2.3)
     127
     128[http://postgis.refractions.net/documentation/manual-1.4/ST_Envelope.html ST_Envelope(geometry)] Returns the minimum bounding box for the supplied geometry, as a geometry. The polygon is defined by the corner points of the bounding box ((MINX, MINY), (MINX, MAXY), (MAXX, MAXY), (MAXX, MINY), (MINX, MINY)). (PostGIS will add a ZMIN/ZMAX coordinate as well). In PostGIS, the bounding box of a geometry is represented internally using float4s instead of float8s that are used to store geometries. The bounding box coordinates are floored, guarenteeing that the geometry is contained entirely within its bounds. This has the advantage that a geometry's bounding box is half the size as the minimum bounding rectangle, which means significantly faster indexes and general performance. But it also means that the bounding box is NOT the same as the minimum bounding rectangle that bounds the geometry.
     129
     130envelope(geometry) (Deprecation in 1.2.3)
     131
     132[http://postgis.refractions.net/documentation/manual-1.4/ST_Extent.html ST_extent(geometry set)]
     133
     134[http://postgis.refractions.net/documentation/manual-1.4/ST_ExteriorRing.html ST_ExteriorRing(geometry)]
     135
     136[http://postgis.refractions.net/documentation/manual-1.4/ST_ConvexHull.html ST_ConvexHull(geometry)]
     137
     138'''Function definitions for WKT Raster 0.1.6'''
     139
     140ST_GetBBox(raster) (not yet implemented but planned) is replaced with ST_Envelope() since there is no more an equivalent ST_GetBBox function in PostGIS.
     141
     142ST_Raster_to_box2d(raster) should be renamed ST_box2d(raster).
     143
     144'''ST_Box2D(raster) -> BOX2D''' - Returns a BOX2D representing the extent of the raster.
     145
     146 If the raster is rotated, the result is a box2d enclosing the rotated raster.
     147
     148 The only difference with ST_Envelope(raster) is that ST_Box2D(raster) returns a BOX2D, not a geometry.
     149
     150 '''Implementation details'''
     151
     152 This function is not anymore available in PostGIS 1.5 and is therefore probably not worth implementing.
     153
     154 This function replaces ST_Raster_to_box2d() and should be used for the "raster AS box2d" cast. It should also be used instead of ST_raster_envelope() when creating indexes in gdal2wktraster.py (to be tested).
     155
     156'''ST_Envelope(raster) -> polygon geometry''' - Returns the minimum bounding box for the supplied raster, as a geometry.
     157
     158 If the raster is rotated, the envelope is a non-rotated box enclosing the rotated raster.
     159
     160 The only difference with ST_Box2D(raster) is that ST_Envelope(raster) returns a geometry, not a BOX2D.
     161
     162
     163 '''Implementation details'''
     164
     165 This function should be implemented as a SQL or a PL/pgSQL function looking like: 'SELECT ST_geometry(ST_Box2D(rast))'
     166
     167 There is already a ST_raster_envelope() function but this has actually the behavior of the ST_ConvexHull(raster) described below. There is also a ticket (#348) related to this function: http://trac.osgeo.org/postgis/ticket/348
     168
     169[[Image(WKTRasterEnvelopeConvexHullAndPolygon.gif)]]
     170
     171'''ST_ConvexHull(raster) -> polygon geometry''' - Returns the minimum convex geometry that encloses every pixel from the raster.
     172
     173 The resulting polygon DOES NOT TAKE the NODATA values into account. The resulting polygon enclose every pixel, even those containing NODATA values. The resulting polygon can be rotated or not depending on the rotation of the raster. If the raster is not rotated ST_ConvexHull(geometry) is (almost) equivalent to ST_Envelope(raster) (ST_Envelope floor the coordinates and hence add a little buffer around the raster).
     174
     175 '''Implementation details'''
     176
     177 This function is actually already implemented by the ST_raster_envelope() function which is wrongly named. There is also a ticket (#348) related to this function: http://trac.osgeo.org/postgis/ticket/348
     178
     179'''ST_Polygon(raster, integer) -> polygon geometry''' - Returns a geometry encomparsing every pixel having a significant value (different than the NODATA value) for the provided band.
     180
     181 This polygon geometry might contain holes if some internal areas of the raster contain pixels with NODATA values.
     182
     183 Variant 1: ST_Polygon(raster) -> polygon geometry -- default to band # 1
     184
     185 '''Implementation details'''
     186
     187 Could also be named ST_Outline().
     188
     189 This function could be roughly implemented as a SQL function looking like 'SELECT ST_Collect((ST_DumpAsPolygons(raster)).geom)'. For sure a more specialised version could be faster than ST_AsPolygon.
     190
     191'''ST_DumpAsPolygons(raster, integer) -> geomval set''' - Returns a set of "geomval" value, one for each contiguous group of pixel sharing the same value for the provided band.
     192
     193 This is a set-returning function (SRF). A "geomval" value is a complex type composed of a polygon geometry (one for each contiguous group of pixel sharing the same value) and the value associated with this geometry. These values are always returned as a value of type double precision. The shape of each polygon follow pixels edges.
     194
     195 Variant 1: ST_DumpAsPolygons(raster) -> geomval set -- default to band # 1
     196
     197 This function should be used with precaution on raster with float pixel type as it could return one "geomval" (or polygon) per pixel. This kind of raster should be reclassified (using the planned ST_Reclassify(raster,...) function) before using ST_DumpAsPolygons().
     198
     199 '''Implementation details'''
     200
     201 This function is at the base of the first version of ST_Intersection which compute the intersection between a raster and a geometry.
     202
     203 To avoid linking directly with PostGIS (see "Why avoid to link with PostGIS?" below) It should be implemented as a SQL wrapper around DumpAsWKTPolygons() looking something like this:
     204
     205 CREATE TYPE geomval AS (geom geometry, val float8);[[BR]]
     206 CREATE TYPE wktgeomval AS (wktgeom text, val float8);
     207
     208 CREATE OR REPLACE FUNCTION ST_DumpAsPolygons(rast raster) RETURNS SETOF geomval AS $$[[BR]]
     209     SELECT ST_GeomFromText(wktgeomval.wktgeom), wktgeomval.val FROM DumpAsWKTPolygons(%1) AS wktgeomval;[[BR]]
     210 $$ LANGUAGE SQL;
     211
     212 It should then be used like this:
     213
     214 SELECT (gv).val, (gv).geom FROM (SELECT ST_DumpAsPolygons(rast) gv FROM sometable) foo
     215
     216[[Image(WKTRasterAsPolygon.gif)]]
     217
     218'''DumpAsWKTPolygons(raster, integer) -> wktgeomval set''' - Returns a set of "geomval" value, one for each group of pixel sharing the same value for the provided band.
     219
     220 Variant 1: DumpAsWKTPolygons(raster) -> wktgeomval set -- default to band # 1
     221
     222 This is a set-returning function (SRF). A "wktgeomval " value is a complex type composed of a the wkt representation of a geometry (one for each group of pixel sharing the same value) and the value associated with this geometry. These values are always returned as a value of type double precision. The shape of each polygon follow pixels edges. Areas with NODATA values are not included in the resulting set.
     223
     224 This function should be used with precaution on raster with float pixel type as it could return one "geomval" (or polygon) per pixel. This kind of raster should be reclassified (using the planned ST_Reclassify(raster,...) function) before using DumpAsWKTPolygons().
     225
     226 DumpAsWKTPolygons() should not be used directly. Use ST_DumpAsPolygons() instead.
     227
     228 '''Implementation details'''
     229
     230 This function construct the WKT strings representing the geometries grouping pixels of a raster having the same value. It does not directly construct geometries and therefore prevent WKT Raster from having to link with liblwgeom.a (see "Why avoid to link with PostGIS?" below) It should also return the value associated with this WKT polygon.
     231
     232 It should be implemented as a C function passing the raster to GDAL and converting each polygon produced by the [http://www.gdal.org/gdal__alg_8h.html GDALPolygonize function] to a WKT string accompagned by its corresponding value in a wktgeomval type. See http://www.postgresql.org/docs/8.4/interactive/xfunc-c.html#AEN44970 on how to return rows and sets in a C function.
     233
     234
     235'''ST_Intersects(raster, integer, geometry) -> boolean''' - Returns TRUE if the geometry and the raster "spatially intersect" - (share any portion of space) and FALSE if they don't (they are disjoint).
     236
     237 Variant 1: ST_Intersects(geometry, raster, integer) -> boolean -- the third parameter is the raster band number
     238
     239 Variant 2: ST_Intersects(geometry, raster) -> boolean -- default to band # 1
     240
     241 Variant 3: ST_Intersects(raster, geometry) -> boolean -- default to band # 1
     242
     243 Variant 4: ST_Intersects(raster, raster) -> boolean
     244
     245 This function permform a full intersection test and proceed in three steps to determine if the raster intersects with the geometry:
     246
     247 1) First, it checks if the bounding box of the raster intersects with the bounding box of the geometry.
     248
     249 2) If the first test returns TRUE, it checks if the geometry returned by ST_ConvexHull(raster) intersects with the geometry.
     250
     251 3) If the second test returns TRUE, it checks if the geometry returned by ST_Polygon(raster, integer) intersects with the geometry. This test is slower since it involve the computation of the raster shape and it might involve the geometry shape. This test takes NODATA values into account. i.e. A geometry intersecting only with a NODATA value area of a raster is NOT actually not intersecting with this raster. This behavior may be controled by limiting the test to certain conditions as stated below.
     252
     253 Variant 4 proceeds in a very similar way except that convex hulls of both rasters are computed and compared in step 2) and both shape of raster are computed and compared in step 3).
     254
     255 If you want to limit the intersection test to the first condition, simply use the && operator. The raster and the geometry will be casted to their respective bounding box (box2d objects):
     256
     257  raster && geometry
     258
     259 If you want to limit the intersection test to the second condition you can write:
     260
     261  ST_Intersects(ST_ConvexHull(raster), geometry)
     262
     263 '''Implementation details'''
     264
     265 This function should be implemented as a pl/pgSQL function performing the three test described one after and conditionally to the other.
     266
     267 It might be faster to skip test 2) if this test is not signicantly faster than test 3).
     268
     269'''ST_Intersection(raster, integer, geometry) -> geometry''' - Returns a set of "geomval" value representing the shared portion of the geometry and the raster band areas sharing a common meaningfull values. The integer parameter is the band number of the raster.
     270
     271 Variant 1:
     272
     273  ST_Intersection(raster, geometry) -> geometry -- default to band # 1[[BR]]
     274  ST_Intersection(geometry, raster, integer) -> geometry -- the integer parameter is the band number of the raster[[BR]]
     275  ST_Intersection(geometry, raster) -> geometry -- default to band # 1
     276
     277 Variant 2:
     278
     279  ST_Intersection(raster, integer, geometry, 'raster') -> raster -- the integer parameter is the band number of the raster[[BR]]
     280  ST_Intersection(raster, geometry, 'raster') -> raster -- default to band # 1
     281
     282 Variant 3:
     283
     284  ST_Intersection(geometry, raster, integer, 'raster') -> raster -- the integer parameter is the band number of the raster[[BR]]
     285  ST_Intersection(geometry, raster, 'raster') -> raster -- default to band # 1
     286
     287 Variant 4:
     288
     289  ST_Intersection(raster, integer, raster, integer) -> raster -- the integer parameters are the band number of the rasters[[BR]]
     290  ST_Intersection(raster, raster, integer) -> raster -- default first raster to band # 1[[BR]]
     291  ST_Intersection(raster, integer, raster) -> raster -- default second raster to band # 1[[BR]]
     292  ST_Intersection(raster, raster) -> raster -- default both rasters to band # 1
     293
     294 Variant 5:
     295
     296  ST_Intersection(raster, integer, raster, integer, 'geometry') -> geometry[[BR]]
     297  ST_Intersection(raster, raster, integer, 'geometry') -> geometry -- default first raster to band # 1[[BR]]
     298  ST_Intersection(raster, integer, raster, 'geometry') -> geometry -- default second raster to band # 1[[BR]]
     299  ST_Intersection(raster, raster, 'geometry') -> geometry -- default both raster to band # 1
     300
     301 This is a set-returning function (SRF). It returns a set of "geomval" representing the point set intersection of the geometry and the areas of the raster sharing a common meaningfull value (NODATA values ARE taken into account). The raster is first polygonised using ST_DumpAsPolygons(raster) and ST_Intersection(geometry, geometry) is then performed between the provided geometry and all the geometries resulting from the polygonisation of the raster.
     302
     303 If the geometries do not share any space (are disjoint), then an empty geometry collection is returned.
     304
     305 ST_Intersection in conjunction with ST_Intersects is very useful for clipping geometries such as in bounding box, buffer, region queries where you only want to return that portion of a geometry that sits in a country or region of interest.
     306
     307 If you only want to compute the intersection between the convex hull of the raster without polygonising it to group of pixels sharing a common value, do:
     308
     309  ST_Intersection(ST_ConvexHull(raster), geometry)
     310
     311 If you only want to compute the intersection between the shape of the raster without polygonising it to group of pixels sharing a common value, do:
     312
     313  ST_Intersection(ST_Polygon(raster), geometry)
     314
     315 '''Implementation details'''
     316
     317 This function should be implemented as a pl/pgSQL function (possibly only a SQL function) performing the intersection between the provided geometry and the table generated by ST_DumpAsPolygons(raster).
     318
     319 Priority 1 should be given to the raster/geometry variants (original and variant 1) returning a geometry.
     320
     321 Priority 2 should be given to the raster/raster variants (5) returning a geometry.
     322
     323 Priority 3 should be given to the other variants (2, 3 & 4) returning a raster. Variant 2 & 3 should be implemented after the planned ST_AsRaster(geometry) function. What should be the raster result of the intersection of two rasters is still to be specified.
     324
    112325
    113326----
