Changes between Version 103 and Version 104 of WKTRaster/SpecificationWorking03
06/13/11 14:05:48 (14 years ago)
pracine
  • TabularUnified WKTRaster/SpecificationWorking03
    v103 v104
    29172917
    29182918  "nband" is assumed to be 1, "quantiles" assumed to be ARRAY[0, 0.25, 0.5, 0.75, 1] and "sample_percent" assumed to be 0.1
     2919
     2920
     2921----
     2922== '''Objective FV.06 - Being able to do some base raster operations.''' - Partially ==
     2923
     2924
     2925'''ST_ValueCount(raster, value) -> integer'''[[BR]]
     2926
     2927ST_ValueCount provides the ability to count the number of times that a user-provided value is present in a raster. To handle floating point values, a rounding argument is provided.
     2928
     2929A set of functions for one or more search values:
     2930
     2931''If NULL is passed for "searchvalues" to any of the ST_ValueCount variations with "searchvalues", the function returns the counts for all unique values''
     2932
     29331. ST_ValueCount(rast raster, nband integer, exclude_nodata_value boolean, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, count)
     2934
     2935    returns the number of times that each value in searchvalues is present in the raster
     2936
     2937    exclude_nodata_value: if FALSE, nodata values in band are considered in the count. if TRUE, nodata values are not considered
     2938
     2939    searchvalues: the set of values to count in the raster
     2940
     2941    roundto: the decimal position to round a pixel value to. Originally intended for use with 32BF and 64BF pixel types, it can also be used with integers when round to the tens, hundreds or higher place.
     2942
     2943        examples are...
     2944
     2945{{{
     2946        roundto < 0: no rounding
     2947
     2948        0: no rounding
     2949
     2950        0.1: round to the tenths place
     2951
     2952        0.01: round to the hundredths place
     2953
     2954        0.001: round to the thousandths place
     2955
     2956        1: round to the ones place
     2957
     2958        10: round to the tens place
     2959
     2960        100: round to the hundreds place
     2961}}}
     2962
     2963{{{
     2964ST_ValueCount(rast, 1, TRUE, ARRAY[23], 0)
     2965
     2966ST_ValueCount(rast, 5, FALSE, ARRAY[3.14], 0.01)
     2967
     2968ST_ValueCount(rast, 2, TRUE, ARRAY[100], 100)
     2969
     2970ST_ValueCount(rast, 1, FALSE, ARRAY[-9999, 0], 1)
     2971
     2972ST_ValueCount(rast, 1, FALSE, NULL::double precision[], 1)
     2973}}}
     2974
     29752. ST_ValueCount(rast raster, nband integer, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, count)
     2976
     2977    exclude_nodata_value is assumed to be TRUE
     2978
     2979{{{
     2980ST_ValueCount(rast, 5, ARRAY[3.14], 0.01)
     2981
     2982ST_ValueCount(rast, 2, NULL::double precision[], 100)
     2983}}}
     2984
     29853. ST_ValueCount(rast raster, nband integer, searchvalues double precision[]) -> setof record (searchvalue, count)
     2986
     2987    roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE
     2988
     2989{{{
     2990ST_ValueCount(rast, 1, ARRAY[-9999])
     2991
     2992ST_ValueCount(rast, 1, NULL::double precision[])
     2993}}}
     2994
     29954. ST_ValueCount(rast raster, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, count)
     2996
     2997    nband is assumed to be 1. exclude_nodata_value is assumed to be TRUE.
     2998
     29995. ST_ValueCount(rast raster, searchvalues double precision[]) -> setof record (searchvalue, count)
     3000
     3001    nband is assumed to be 1. roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE.
     3002
     3003A set of functions for a single search value:
     3004
     30051. ST_ValueCount(rast raster, nband integer, exclude_nodata_value boolean, searchvalue double precision, roundto double precision) -> integer
     3006
     3007    returns the number of times that searchvalue is present in the raster
     3008
     3009    searchvalue: the value to count in the raster
     3010
     3011{{{
     3012ST_ValueCount(rast, 1, TRUE, 23, 0)
     3013
     3014ST_ValueCount(rast, 5, FALSE, 3.14, 0.01)
     3015
     3016ST_ValueCount(rast, 2, TRUE, 100, 100)
     3017
     3018ST_ValueCount(rast, 1, FALSE, -9999, 1)
     3019}}}
     3020
     30212. ST_ValueCount(rast raster, nband integer, searchvalue double precision, roundto double precision) -> integer
     3022
     3023    exclude_nodata_value is assumed to be TRUE
     3024
     3025{{{
     3026ST_ValueCount(rast, 5, 3.14, 0.01)
     3027
     3028ST_ValueCount(rast, 2, 100, 100)
     3029}}}
     3030
     30313. ST_ValueCount(rast raster, nband integer, searchvalue double precision) -> integer
     3032
     3033    roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE
     3034
     3035{{{
     3036ST_ValueCount(rast, 1, -9999)
     3037}}}
     3038
     30394. ST_ValueCount(rast raster, searchvalue double precision, roundto double precision) -> integer
     3040
     3041    nband is assumed to be 1. exclude_nodata_value is assumed to be TRUE.
     3042
     30435. ST_ValueCount(rast raster, searchvalue double precision) -> integer
     3044
     3045    nband is assumed to be 1. roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE.
     3046
     3047The set of functions for processing coverages return "bigint" instead of "integer".
     3048
     3049A set of functions for one or more search values:
     3050
     30511. ST_ValueCount(rastertable text, rastercolumn text, nband integer, exclude_nodata_value boolean, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, count)
     3052
     3053    rastertable: name of the table with a raster column
     3054
     3055    rastercolumn: name of the raster column
     3056
     3057{{{
     3058ST_ValueCount('test', 'rast', 1, TRUE, ARRAY[23], 0)
     3059
     3060ST_ValueCount('test', 'rast', 5, FALSE, ARRAY[3.14], 0.01)
     3061
     3062ST_ValueCount('test', 'rast', 2, TRUE, ARRAY[100], 100)
     3063
     3064ST_ValueCount('test', 'rast', 1, FALSE, ARRAY[-9999, 0], 1)
     3065
     3066ST_ValueCount('test', 'rast', 1, FALSE, NULL::double precision[], 1)
     3067}}}
     3068
     30692. ST_ValueCount(rastertable text, rastercolumn text, nband integer, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, count)
     3070
     3071    exclude_nodata_value is assumed to be TRUE
     3072
     3073{{{
     3074ST_ValueCount('test', 'rast', 5, ARRAY[3.14], 0.01)
     3075
     3076ST_ValueCount('test', 'rast', 2, NULL::double precision[], 100)
     3077}}}
     3078
     30793. ST_ValueCount(rastertable text, rastercolumn text, nband integer, searchvalues double precision[]) -> setof record (searchvalue, count)
     3080
     3081    roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE
     3082
     3083{{{
     3084ST_ValueCount('test', 'rast', 1, ARRAY[-9999])
     3085
     3086ST_ValueCount('test', 'rast', 1, NULL::double precision[])
     3087}}}
     3088
     30894. ST_ValueCount(rastertable text, rastercolumn text, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, count)
     3090
     3091    nband is assumed to be 1. exclude_nodata_value is assumed to be TRUE.
     3092
     30935. ST_ValueCount(rastertable text, rastercolumn text, searchvalues double precision[]) -> setof record (searchvalue, count)
     3094
     3095    nband is assumed to be 1. roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE.
     3096
     3097A set of functions for a single search value:
     3098
     30991. ST_ValueCount(rastertable text, rastercolumn text, nband integer, exclude_nodata_value boolean, searchvalue double precision, roundto double precision) -> bigint
     3100
     3101    searchvalue: the value to count in the raster
     3102
     3103{{{
     3104ST_ValueCount('test', 'rast', 1, TRUE, 23, 0)
     3105
     3106ST_ValueCount('test', 'rast', 5, FALSE, 3.14, 0.01)
     3107
     3108ST_ValueCount('test', 'rast', 2, TRUE, 100, 100)
     3109
     3110ST_ValueCount('test', 'rast', 1, FALSE, -9999, 1)
     3111}}}
     3112
     31132. ST_ValueCount(rastertable text, rastercolumn text, nband integer, searchvalue double precision, roundto double precision) -> bigint
     3114
     3115    exclude_nodata_value is assumed to be TRUE
     3116
     3117{{{
     3118ST_ValueCount('test', 'rast', 5, 3.14, 0.01)
     3119
     3120ST_ValueCount('test', 'rast', 2, 100, 100)
     3121}}}
     3122
     31233. ST_ValueCount(rastertable text, rastercolumn text, nband integer, searchvalue double precision) -> bigint
     3124
     3125    roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE
     3126
     3127{{{
     3128ST_ValueCount('test', 'rast', 1, -9999)
     3129}}}
     3130
     31314. ST_ValueCount(rastertable text, rastercolumn text, searchvalue double precision, roundto double precision) -> bigint
     3132
     3133    nband is assumed to be 1. exclude_nodata_value is assumed to be TRUE.
     3134
     31355. ST_ValueCount(rastertable text, rastercolumn text, searchvalue double precision) -> bigint
     3136
     3137    nband is assumed to be 1. roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE.
     3138
     3139----
     3140
     3141'''ST_ValuePercent(raster, value) -> double precision'''[[BR]]
     3142
     3143ST_ValuePercent is the sibling of ST_ValueCount and returns the percentage of a raster's band that is of a specified value. To handle floating point values, a rounding argument is provided.
     3144
     3145A set of functions for one or more search values:
     3146
     3147''If NULL is passed for "searchvalues" to any of the ST_ValuePercent variations with "searchvalues", the function returns the percents for all unique values''
     3148
     31491. ST_ValuePercent(rast raster, nband integer, exclude_nodata_value boolean, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, percent)
     3150
     3151    returns the percentage of a raster's band that each value in searchvalues is found
     3152
     3153    exclude_nodata_value: if FALSE, nodata values in band are considered in the percents. if TRUE, nodata values are not considered
     3154
     3155    searchvalues: the set of values to get percents for in the raster
     3156
     3157    roundto: the decimal position to round a pixel value to. Originally intended for use with 32BF and 64BF pixel types, it can also be used with integers when round to the tens, hundreds or higher place.
     3158
     3159        examples are...
     3160
     3161{{{
     3162        roundto < 0: no rounding
     3163
     3164        0: no rounding
     3165
     3166        0.1: round to the tenths place
     3167
     3168        0.01: round to the hundredths place
     3169
     3170        0.001: round to the thousandths place
     3171
     3172        1: round to the ones place
     3173
     3174        10: round to the tens place
     3175
     3176        100: round to the hundreds place
     3177}}}
     3178
     3179{{{
     3180ST_ValuePercent(rast, 1, TRUE, ARRAY[23], 0)
     3181
     3182ST_ValuePercent(rast, 5, FALSE, ARRAY[3.14], 0.01)
     3183
     3184ST_ValuePercent(rast, 2, TRUE, ARRAY[100], 100)
     3185
     3186ST_ValuePercent(rast, 1, FALSE, ARRAY[-9999, 0], 1)
     3187
     3188ST_ValuePercent(rast, 1, FALSE, NULL::double precision[], 1)
     3189}}}
     3190
     31912. ST_ValuePercent(rast raster, nband integer, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, percent)
     3192
     3193    exclude_nodata_value is assumed to be TRUE
     3194
     3195{{{
     3196ST_ValuePercent(rast, 5, ARRAY[3.14], 0.01)
     3197
     3198ST_ValuePercent(rast, 2, NULL::double precision[], 100)
     3199}}}
     3200
     32013. ST_ValuePercent(rast raster, nband integer, searchvalues double precision[]) -> setof record (searchvalue, percent)
     3202
     3203    roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE
     3204
     3205{{{
     3206ST_ValuePercent(rast, 1, ARRAY[-9999])
     3207
     3208ST_ValuePercent(rast, 1, NULL::double precision[])
     3209}}}
     3210
     32114. ST_ValuePercent(rast raster, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, percent)
     3212
     3213    nband is assumed to be 1. exclude_nodata_value is assumed to be TRUE.
     3214
     32155. ST_ValuePercent(rast raster, searchvalues double precision[]) -> setof record (searchvalue, percent)
     3216
     3217    nband is assumed to be 1. roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE.
     3218
     3219A set of functions for a single search value:
     3220
     32211. ST_ValuePercent(rast raster, nband integer, exclude_nodata_value boolean, searchvalue double precision, roundto double precision) -> integer
     3222
     3223    searchvalue: the value to get a percent for in the raster
     3224
     3225{{{
     3226ST_ValuePercent(rast, 1, TRUE, 23, 0)
     3227
     3228ST_ValuePercent(rast, 5, FALSE, 3.14, 0.01)
     3229
     3230ST_ValuePercent(rast, 2, TRUE, 100, 100)
     3231
     3232ST_ValuePercent(rast, 1, FALSE, -9999, 1)
     3233}}}
     3234
     32352. ST_ValuePercent(rast raster, nband integer, searchvalue double precision, roundto double precision) -> integer
     3236
     3237    exclude_nodata_value is assumed to be TRUE
     3238
     3239{{{
     3240ST_ValuePercent(rast, 5, 3.14, 0.01)
     3241
     3242ST_ValuePercent(rast, 2, 100, 100)
     3243}}}
     3244
     32453. ST_ValuePercent(rast raster, nband integer, searchvalue double precision) -> integer
     3246
     3247    roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE
     3248
     3249{{{
     3250ST_ValuePercent(rast, 1, -9999)
     3251}}}
     3252
     32534. ST_ValuePercent(rast raster, searchvalue double precision, roundto double precision) -> integer
     3254
     3255    nband is assumed to be 1. exclude_nodata_value is assumed to be TRUE.
     3256
     32575. ST_ValuePercent(rast raster, searchvalue double precision) -> integer
     3258
     3259    nband is assumed to be 1. roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE.
     3260
     3261The set of functions for processing coverages return "bigint" instead of "integer".
     3262
     3263A set of functions for one or more search values:
     3264
     32651. ST_ValuePercent(rastertable text, rastercolumn text, nband integer, exclude_nodata_value boolean, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, percent)
     3266
     3267    rastertable: name of the table with a raster column
     3268
     3269    rastercolumn: name of the raster column
     3270
     3271{{{
     3272ST_ValuePercent('test', 'rast', 1, TRUE, ARRAY[23], 0)
     3273
     3274ST_ValuePercent('test', 'rast', 5, FALSE, ARRAY[3.14], 0.01)
     3275
     3276ST_ValuePercent('test', 'rast', 2, TRUE, ARRAY[100], 100)
     3277
     3278ST_ValuePercent('test', 'rast', 1, FALSE, ARRAY[-9999, 0], 1)
     3279
     3280ST_ValuePercent('test', 'rast', 1, FALSE, NULL::double precision[], 1)
     3281}}}
     3282
     32832. ST_ValuePercent(rastertable text, rastercolumn text, nband integer, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, percent)
     3284
     3285    exclude_nodata_value is assumed to be TRUE
     3286
     3287{{{
     3288ST_ValuePercent('test', 'rast', 5, ARRAY[3.14], 0.01)
     3289
     3290ST_ValuePercent('test', 'rast', 2, NULL::double precision[], 100)
     3291}}}
     3292
     32933. ST_ValuePercent(rastertable text, rastercolumn text, nband integer, searchvalues double precision[]) -> setof record (searchvalue, percent)
     3294
     3295    roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE
     3296
     3297{{{
     3298ST_ValuePercent('test', 'rast', 1, ARRAY[-9999])
     3299
     3300ST_ValuePercent('test', 'rast', 1, NULL::double precision[])
     3301}}}
     3302
     33034. ST_ValuePercent(rastertable text, rastercolumn text, searchvalues double precision[], roundto double precision) -> setof record (searchvalue, percent)
     3304
     3305    nband is assumed to be 1. exclude_nodata_value is assumed to be TRUE.
     3306
     33075. ST_ValuePercent(rastertable text, rastercolumn text, searchvalues double precision[]) -> setof record (searchvalue, percent)
     3308
     3309    nband is assumed to be 1. roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE.
     3310
     3311A set of functions for a single search value:
     3312
     33131. ST_ValuePercent(rastertable text, rastercolumn text, nband integer, exclude_nodata_value boolean, searchvalue double precision, roundto double precision) -> bigint
     3314
     3315    searchvalue: the value to get a percent for in the raster
     3316
     3317{{{
     3318ST_ValuePercent('test', 'rast', 1, TRUE, 23, 0)
     3319
     3320ST_ValuePercent('test', 'rast', 5, FALSE, 3.14, 0.01)
     3321
     3322ST_ValuePercent('test', 'rast', 2, TRUE, 100, 100)
     3323
     3324ST_ValuePercent('test', 'rast', 1, FALSE, -9999, 1)
     3325}}}
     3326
     33272. ST_ValuePercent(rastertable text, rastercolumn text, nband integer, searchvalue double precision, roundto double precision) -> bigint
     3328
     3329    exclude_nodata_value is assumed to be TRUE
     3330
     3331{{{
     3332ST_ValuePercent('test', 'rast', 5, 3.14, 0.01)
     3333
     3334ST_ValuePercent('test', 'rast', 2, 100, 100)
     3335}}}
     3336
     33373. ST_ValuePercent(rastertable text, rastercolumn text, nband integer, searchvalue double precision) -> bigint
     3338
     3339    roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE
     3340
     3341{{{
     3342ST_ValuePercent('test', 'rast', 1, -9999)
     3343}}}
     3344
     33454. ST_ValuePercent(rastertable text, rastercolumn text, searchvalue double precision, roundto double precision) -> bigint
     3346
     3347    nband is assumed to be 1. exclude_nodata_value is assumed to be TRUE.
     3348
     33495. ST_ValuePercent(rastertable text, rastercolumn text, searchvalue double precision) -> bigint
     3350
     3351    nband is assumed to be 1. roundto is assumed to be 0, so no rounding takes place. exclude_nodata_value is assumed to be TRUE.
