Changes between Version 178 and Version 179 of WKTRaster/SpecificationWorking03
- 11/29/11 11:27:48 (13 years ago)
TabularUnified WKTRaster/SpecificationWorking03
v178 v179 524 524 END IF 525 525 526 ---- 527 == '''Objective FV.22 - Making raster_columns and raster_overview as views''' == 528 529 Following the conversion of geometry_columns to a view in PostGIS, it is planned to do the same with raster_column and raster_overview for the raster part. Converting to a view has a number of advantages: 530 531 PostGIS is using the typmod feature of PostgreSQL to 'store' metadata about a table and then display them in the geometry_column view. Unfortunately the typmod is limited to XXX byte and there is too much information to 'store' about a raster table to use typmod. PostGIS raster will therefore use another technique to 'store' metadata about a raster table: constraint. A set of constraint will be applied to a raster table and those constraint will be read and displyed by the raster_column view. 526 532 527 533 ----
